Angryfox
Page 1 of 6 123456 LastLast
Results 1 to 30 of 164
Thread: NOT JUST ANOTHER THOR MOD !! (the Maxablaster!)
    Flashaholic* Ra's Avatar
    Jul 2004
    The Netherlands
    Au NOT JUST ANOTHER THOR MOD !! (the Maxablaster!)
    Hi guyz, A short while ago I made my dream (which I had for years) reality:
    A mercury-arc Cyclops Thor mod:
    Playing with Maxabeam for over four years I wanted to create a light that was even more powerfull, not only in lumens output, but in throw as well.
    The osram HBO 103/W2 produces 3000 bulb lumens and has the highest possible surface brightness ( exept for lasers ofcource )
    Combined with a high quality parabolic Rhodium reflector this gives close to 40 million cp. (measured using calibrated equipment)
    It took two months to complete this monster.
    Putting 54 NiMh 3300mAh cells together was a difficult job on its own !
    The ballast has a 18-36 volt input range so I combined 3 groups of 16 cells to get 19.2 volt at 9.9 Ah, enough for 100 minutes of operation time.
    Using mercury-arc comes with a few hazards: It radiates the complete harmful ultra violet spectrum in the book: Toxic ozone generating UV-C included ! So I made shure that the front window blocks all of the UV-C and UV-B and most of the less harmfull UV-A.
    The front window also has to protect me against lamp-burst: The lamp has lower than atmospheric pressure when cold, but generates +85 atm's in full operation!
    The device is thermal protected and a key-lock prevents accidental ignition, its not a toy!
    The lamp is adustable in all directions with a precision of 0.01 mm, nessessary with a arc surface of just over 0.1 of a square mm.
    38 million cp's create a spot on clouds up to 4 miles high with ease:
    And compared to Maxabeam: see for your selves:
    For max throw surface brightness is the most important, the next picture will show the difference in surface brightness of a few lamps: in the middle Maxabeam at high power, at the right the mercury-arc thor and to the left the very faint contours of my HID Thor at 50watt power! The picture was taken using a type 13 welding filter.
    So,,, any questions??
    Flashaholic pyro's Avatar
    Aug 2003
    Germany
    Default Re: NOT JUST ANOTHER THOR MOD !!
    WOW!
    Where did you get that beautiful reflector?
    I dont even dare to ask what it cost you to build this Maxabeam Crusher.
    Really impressive!
    Flashaholic* x-ray's Avatar
    Jul 2002
    London
    Amazing light
    He who laughs last, thinks slowest
    Jul 2004
    The Netherlands
    Wink2 Re: NOT JUST ANOTHER THOR MOD !!
    Thanks pyro,
    Yes, it is a quite expensive project: The reflector costs about 800 USD! Its a very high quality reflector used in lab-equipment. The total costs of the materials is about 2000 USD. But it was worth it (in my opinion...)
    Flashaholic Taylorf's Avatar
    Dec 2005
    Missouri
    Wow, awesome.
    What is the purpose of the LEDs on top of it?
    My small collection: Surefire 8ax, Orb Raw, Costco 10 million and 15 million, Streamlight Ultrastinger, and the Exolion
    Jul 2004
    The Netherlands
    And to give an impression of the smoothness of the reflector:
    BTW, Here Maxablaster runs with a Ushio UXL 75-XE xenon short-arc (With the same specs as the lamp of Maxabeam.)
    Regards,
    Ra.
    Jul 2004
    The Netherlands
    Thanks Taylorf,
    The led's are for voltage check during operation: low voltage can damage the electronic ballast that operates the lamp. So if the two red ones bigin to light up its advisable to turn off the lamp!
    Hi Ra,
    i'm impressed on all, many compliments......a couple of questions:
    1) Why Rhodium plated and not silver plated? Silver is better than any coating, but Rhodium don't take oxidation...zero maintenance.
    2) You have projected also the entire reflector design or it is stock thor reflector coated?
    3) What brand is the ballast?
    4) As you have balanced perfectly all cells to make a battery pack?
    .....for now, just these questions
    Jul 2004
    The Netherlands
    Rhodium is the most durable, is very hard and can easily cope with the high levels of ultra violet light produced by the lamp.
    The original Thor-reflector has too many imperfections in its shape and can only be used with larger filaments or with HID.
    The ballast is a Auerswald.
    The batteries are hand picked and checked on their capacity.
    *Flashaholic* PoliceScannerMan's Avatar
    Jul 2005
    Gainesville,FL
    Very nice! Good Job!
    Can you post a large pic of your Avatar, it also shows the smooth reflector.
    That light looks awesome, a real Throw King!
    dude, your good!
    *Flashaholic* greenLED's Avatar
    Mar 2004
    La Tiquicia
    "just another mod"??
    Dude, that's awesome! Next thing you know, you'll be rebuilding a tank light.
    Nice job.
    Feb 2005
    This is the type of stuff I joined CPF to see....Awesome job!
    Flashaholic* CroMAGnet's Avatar
    Sep 2004
    Los Gatos, CA
    Buttrock Re: NOT JUST ANOTHER THOR MOD !!
    Way to go! This light needs a catchy name so we can find it in a search months from now.
    Jan 2005
    Texas, USA, Earth
    Well, I am absolutely floored
    Will
    Please no PM/Visitor Msg's. Email for questions/Paypal: wquiles [at] gmail {dot} com
    Jan 2005
    Texas, USA, Earth
    Quote Originally Posted by CroMAGnet
    How about "Master-Blaster" ???
    (bonus points: remember what movie this is from?)
    Will
    Aug 2004
    Sydney, Australia
    Ra
    Ra-ra
    You ARE the Sun-God.
    Wow is all I can say.
    So what is your EDC?
    Kind Regards
    David
    Aug 2005
    Live: Paramaribo, Suriname, South America / Study: Rotterdam, The Netherlands
    Wanneer mag ik deze ook eens persoonlijk bezichtigen ?
    (Dutch for: When can I visit ?)
    Great efforts !! Cheers !!
    Dec 2002
    South Florida, USA
    Awesome light. How much does that thing weigh? That is a lot of batteries. It has got to be pretty heavy right?
    Curtis
    -- CUE
    Dec 2005
    Clifton, NJ
    WOAH!
    Master Blaster was from Mad Max III.
    *Flashaholic*
    tvodrd's Avatar
    Dec 2002
    Hawthorne, NV
    Awsome!!!!!!!
    Larry
    So much for not being able to find my happy a** with both hands and a flashlight! (Do not look into Tank Searchlight with remaining eye!)
    *Flashaholic* Icebreak's Avatar
    Aug 2002
    by the river
    I'm in awe.
    When I saw the spectacularly bright image return you got a 800yds I was trying to imagine the throw limit at about 2mi but this thing dances with clouds four mi away. I would truly like to see that thing in person.
    There so many wonderful components to your light. I'll mention one I especially like. The way you can precision focus it with three axises. Man that takes some creative thinking and heavy skills to build that focusing apparatus.
    What a stunner.
    The oldtimers are forever bound to the universe of flashlights. They reside just above the torch lit stratosphere where the good photons pass by. As these oldtimers locomote on their appointed ways, occasionally an unusual glimmer from below catches their attention.
    They may give a nod or a word.
    Flashaholic* Lips's Avatar
    Mar 2005
    Louisiana - USA
    Great work!!!
    Jul 2004
    The Netherlands
    Help Re: NOT JUST ANOTHER THOR MOD !!
    Whoww,, Idid not expect this to happen. I don't have much time now, must go to work. So I'll be back later. But I can answer one question PoliceScannerMan: My avatar is part of the following:
    Greetings from Holland.
    DROOL!
    Flashaholic* Delvance's Avatar
    Nov 2005
    Sydney, Australia
    Absolutely amazing. I am speechless. Art.
    Flashaholic* roguesw's Avatar
    Dec 2002
    Tokyo, Japan
    to steal a line from another thread
    "What ever you do guys, dont cross the beams"
    that is an amazing mod, straight out of the movies
    KL-4+Vital Gear FB02
    Pr-t (TWOK) + DB700 + E2E
    Pr (WXOT) + BB700 + E20
    M3T + rcr 123's
    Will build for free!!
    Is it possible to use two 12V SLA mini batteries? Combined, it looks to be the same size as the original battery. I saw some of the small batteries that were half the size of the one that comes in the original Thor at Fry's. I think they were 7Ah rated and about $14 apiece, IIRC.
    Jeff
    Time to upgrade the dinosaurs, one at a time.
    Flashaholic* jar3ds's Avatar
    Sep 2005
    USA
    if your feeling giving.. i'll take it ...
    excellent build!
    Good god man!!!!! That thing is ridiculous. I love it.
