Kryosphinx
This mod is VERY easy. All you need is a soldering iron, a steady hand, and a couple resistors.
1. Open KL1 head and reveal the circuit
2. Take a resistor and solder it parallel to the circled resistor.
CM says, The latest version uses a 0.68ohm sense resistor. For 750mA, you need a one ohm resistor in parallel with the 0.68ohm resistor. I just stack it on top of the existing resistor.
I used two 1.5 ohm resistors parallel to get ~770ma.
That's it!
That's it!
