ArmyTek
Page 1 of 3 123 LastLast
Results 1 to 30 of 73
Thread: My little 10Watt HID MONSTER
    Flashaholic* Ra's Avatar
    Jul 2004
    The Netherlands
    Wink2 My little 10Watt HID MONSTER
    Hi guyz, its me again...
    Here another project I completed a short while ago:
    Its a very powerfull 10watt mini HID torch: 250,000 peak beam CP. Its waterresistand up to depths of 200 ft. Has +2 hours of burntime on one charge.
    The reflector is made from an used projector-bulb: This perfect parabolic dichoric (cold) reflector is capable of withstanding extreme temperatures and has more than 98% overall reflection.
    The green ring has a little magnet embedded, switching a reed-switch inside the torch. This reed triggers two 2amp power relays placed in the reflector-compartment: A highly durable, most waterresistand solution.
    I removed the protective bulb from the Solarc 10watt HID lamp to gain a few % of lumens and to prevent "optical arc dissplacement"
    The lamp is cemented very exactly in the reflector to obtain a nearly perfect beampattern with a 250,000 Cp hotspot in the middle:
    The inside is quite simple: Using three 2.4Ah 18650 Li-Ion cells. Each cell has its own connector at the back of the torch.
    The inside temperature is kept well within specs by the large heatsink at the outside of the lamphead: its completely surrounding the ballast. The inside temp. doesn't rise more than 15 deg. centigrade above the environment-temp. during continous operation.
    The high-candlepower hotspot in the center of the beam is created by a very small hotspot in the arc near the anode:
    The surface brightness of this hotspot is several times higher than the mean surface brightness of the entire arc.
    To successfully concentrate the light of this hotspot you need a perfect parabolic reflector. And you need to remove the protective bulb which causes an optical effect that makes parabolic reflectors useless for this purpose!
    The front window it a multilayer coated quartz window 4mm thick, hardly visible on the pics due to its high transmission: 99.3%!
    All this adds up: 98% reflective reflector, removed protective bulb, overdriven lamp and 99.3% transmitting window: Making most torchlumens out of bulblumens.
    Wanna know more, ask me!
    Flashaholic* Long John's Avatar
    Mar 2006
    Spain, near Cadiz
    Default Re: My little 10Watt HID MONSTER
    Hello Ra
    Wowwwwww, that's a HID, ohhhh sorry
    Thats THE HIT........
    Best regards
    _____
    Tom
    Flashaholic* JimH's Avatar
    Apr 2004
    San Jose, CA
    Very, very nice. Did you make the body from scratch or start with salvaged parts from something else?
    Jim - Have lights, lead, and steel will travel
    The heck with runtime. I just want to hold the sun in my hands!! Brighter is Better!
    Jul 2004
    The Netherlands
    Thumbs up Re: My little 10Watt HID MONSTER
    Thanks guyz,
    I totally designed the torch myself, a highly skilled friend of mine helped machining the black annodized aluminum parts.
    Flashaholic* ACMarina's Avatar
    Sep 2004
    Brookston, IN
    Is that a ping-pong ball next to it??
    I love my Al-PD
    Oct 2004
    Bonner Springs, KS
    Excellent job, where did the reflector come from?
    |Nuwai|GLP's|Aleph 3|PR-T w/E2e|Costco HID's|ARC LSH-S| Mr Bulk|Lumaray FL12|PocketMateW|MagHID|Mag85|AWR Nano|Amilite|SFIII Mc38-V|TnC Lithium Lux V XYOS 03/10|Fenix Trio|SuperNova|Illuminator|PGL-III-A's| Gatlight SS V2|Nitrous McLuxIII PD|USL|AN/VSS-3a|FM Ni Plt'd C Mag|FM 3.5" Mag Head|
    Jul 2004
    The Netherlands
    Yep, a ping-pong ball, with hair (as much hair as I have), two eyes, a nose and a mouth.. Its to give a better impression of the size of the torch.
    *Flashaholic* jtice's Avatar
    May 2003
    West Virginia
    Another excellent project !
    Flashaholic zelda's Avatar
    Aug 2005
    Zurich, Switzerland
    Wow thats a nice torch!
    Today, most beamerlamps have a Rectangular reflector
    Good idea with a reed-switch.
    zelda
    Flashaholic ledvador's Avatar
    Oct 2004
    Land of Eiffel Tower
    This is a very nice job. Have you got some beamshot comparison?
    I like very mutch your CAD drowing software.
    Jul 2004
    The Netherlands
    Zelda said:
    "Today, most beamerlamps have a Rectangular reflector"
    Yes, thats a problem making torches like these, you'll have to bump onto a nice, usable reflector. BTW this was a rectangular reflector, but it was much larger. I machined it down, losing the rectangular part. Its from a Hitachi CP-X960 projector lamp.
    Yeah, I have a question. How much are you going to sell it to me for?
    Jeff
    Time to upgrade the dinosaurs, one at a time.
    Jul 2004
    The Netherlands
    Au Re: My little 10Watt HID MONSTER
    Be strong Jeff,
    I see you already have too many lights.
    Do you have any idea of the time I need to make one of these ?? I don't want to dissapoint other torchlovers, but its not likely I'm going to produce these torches, I simply don't have the time.
    Apr 2004
    San Jose, CA
    I'll bet if you sat down and added all the money you have wrapped up in this light, it would scare even you. Remember you have to account for all your time and labor and your friend's time and labor at reasonable rates for engineering design and production. You also have to throw in the cost of machine time. All of this is on top of all material costs, including the stuff that had to be thrown away.
    I know these projects tend to take on a life of their own. I'm glad yours turned out so well. It's a fantastic job.
    Flashaholic* iced_theater's Avatar
    Oct 2005
    Green River, Wyoming
    That's an awesome light. If you have other 10 watt HID's you should compare them to show the difference.
    Feb 2005
    For anyone who missed the thread this is a link to his other "Monster!"
    http://candlepowerforums.com/vb/showthread.php?t=125819
    Flashaholic* Icarus's Avatar
    Nov 2003
    Belgium
    Very nice mod!
    Apr 2004
    San Jose, CA
    Quote Originally Posted by Icarus
    Very nice mod!
    I'd hardly call it a "mod" since it was built from scratch.
    Flashaholic* mst3k's Avatar
    Dec 2002
    Southern California
    So, how long from dream to completion on this bad boy??
    Im guessin considerably under a year, right?
    No matter where you go there you are!
    Now, this is a very tempting thing.
    Where would one get the necessary componants...?
    Thanks!
    -Gary
    Jul 2004
    The Netherlands
    Lightbulb Re: My little 10Watt HID MONSTER
    Quote Originally Posted by mst3k
    In fact its over a year! The design was already taking shape more than a year ago, but the hard part is finding a reflector accurate enough for this project.
    The manufacturing of the little beast took about two months.
    The reflector was the most difficult to make, its made out of very hard ceramic material. The ballast and lamp I grabbed out of a UK Light Canon 100. The 18650 cells from Ebay.
    The best I can come up with to compare it to is a pistol-grip halogen torch I modified a few years ago: a 6volt 30watt projection bulb is overdriven at 7.2 volts. This torch puts out 225,000 beam CP (calibrated measurement.)
    I'll make some beamshots if I can find the time today.
    Laterrr.
    Feb 2006
    Albuquerque, NM
    Wow!
    Jul 2004
    The Netherlands
    Exclamation More Beamshots...
    Later tonight I'll come up with beamshots taken in the field, but for now:
    And...
    Looks like one of the nebulae in space....doesn't it??
    And for surface brightness:
    Ra.
    Flashaholic* Delvance's Avatar
    Nov 2005
    Sydney, Australia
    Ra,
    Once again, just art.
    (pppsss hehe...hrmmm *wakes up* damn!)
    Oct 2005
    Northborough _ MA USA
    Ummmmm I Would like to buy one.....
    Put me on the list.
    M.TEX
    M.TEX
    Beautiful. The size and burn time make me drool. I'd like a rugged version that gave up on precision for strenght that I could carry with me as a volunteer firefighter/EMT.
    A snap on for wide angle/closer work would make it perfect.
    And while the black is beautiful a bright orange or yellow would make it easier to find if dropped on a job...
    (And a $24.98 price tag while I dream...)
    Very impressive. You really have a great design talent. I'm sure a limited run of these lights would sell instantly. Great work
    Flashaholic* monkeyboy's Avatar
    Mar 2006
    UK
    Nice work once again
    I think this is an excellent choice of battery configuration. What sort of runtimes do you get with the 3x 2400mah 18650s? Did you know they make 2600s?
    http://www.batteryspace.com/index.as...OD&ProdID=2763
    Jul 2004
    The Netherlands
    Well Monkeyboy, it runs just over two hours on one charge.
    And ...I din't know about the 2600 mAh cells... I'm going to order a few of them! Thanks for the tip.
    Regards,
    Ra
    Aug 2005
    Live: Paramaribo, Suriname, South America / Study: Rotterdam, The Netherlands
    This might get me into HID's....
    What is the host, and was the switch a Mod, or Standard ?
    Cheers !!
