I have this mini lathe and somtimes I will try different types of looks for the Mini-Mag. I wanted horizontal grooves. I attached a Dremel tool to the tool post and attempted cut grooves. The Dremel may be good for some things, but not this. The carbide cutter would dig in and chatter, the stones, even with cutting oil would just wear away. I ended up with this,
Just did not look right. So - back to the lathe I went. I have some purpleheart wood here and I thought - let me try something a little different. During one of the cuts on the lathe the head came loose and did some damage to the knurling around the head.
Some epoxy glue to hold the halfs together on the turned down head and body and I ended up with this.
second time is a charm. Zebra Wood....
( notice the purple heart is changing color )
