treasurydept said:
Which LED would be better to use to mod a HDS U60 (not 42); an S bin Lux I or a U bin Lux III?
They are probably both the same thing, just sold differently (binned at different currents). Don't sweat it. Choose whatever is available in the tint bin you want, but keep in mind that a Lux1 will move toward pink at currents higher than the 350 mA it is binned at (the HDS on Max), while a Lux3 will move toward green at currents lower than it is binned at (the HDS below Max). Fortunately, since the HDS uses PWM dimming, the tint shift will not be large.
Also keep in mind that you may not get a remarkable brightness increase by trying to upgrade an HDS U60, but if you are doing it to get a different tint it may be worthwhile to you.
