hotfoot
(Down with the flu now and not in the mood for "real work", so I decided to put this together and post it
I'm sure all of the modders here know what a grand pain it is to eye-sort luxeons (yes, even the known-binned ones) to ensure only the creme-de-la-creme make it into our mods.
We all know you can't always trust the binning info and that the info doesn't tell you which emitter in a reel is the brightest of them all. Worse still - it doesn't tell you which ones are duds or black sheep underperformers.
And while the eyes are the best judge most of the time, sometimes you just plain don't have the time, conditions or repeatability to the testing. So, when you receive a coupla reels of binned luxeons (that's 500 of them), how do you know which ones deserve to go into your personal "keepers", or some other special mod?
Well, there are probably lotsa ways to do this, but here's the method I devised that helps the process along for me (photo essay):
The simple setup above is portable and allows quick, easy and repeatable test conditions.
Never thought I'd use a McFlood reflector this way, but hey - it works!
The emitter is held at a fixed distance and angle from the sensor by the McFlood. Very quick and very easy and works every time.
Instead of the mini-plugs, you can use bare wires if you prefer if you don't mind worrisome accidental shorting every now and then. Banana jacks will do fine too. That's masking tape you see wrapped around the mini-plugs and it was used by me to "shim" the distance between the 2 probe terminals til they were exactly that of the luxeons legs. So, all I need to do is just bring the probes to the mounted emitter and touch it on its legs.
With the above setup, I could sort thru a whole reel in 2-3 hours at a well-lit and crowded workdesk. I had paper cups with my own flux "grades" written on them. After I measured an emitter, I just threw it into the cup which most closely matched its "grade".
Of course, even the sorted ones would go thru additional eye-sorting since the luxmeter doesn't tell you the color of what you test - only its brightness. But at least you'd have a helluva lot fewer emitters to bother with since you already know which are the brightest
