Hiker
Here are some newbie (me) questions. I am interested in testing NIMH & non-charging lithiums, mainly AAA/AA. I do not want an expensive tester - idealy under $30.
After doing a search regarding battery testers in this forum I actually am more confused - so here goes:
1. Can you reliably test how much remaining charge either type has?
2. Can you reliably test the condition of the battery regarding relating to it's life cycle?
While I am at it:
3. Does it actually diminish the NIMH battery's life or charging ability to charge it more often or when it is only partially discharged? It seems that one of the advantages of a tester would be to know when it is best to charge it if this actually matters. Otherwise I would charge them more frequently just to make sure they were they did not run out.
Thanks for your help and patience.
While I am at it:
