Here's another point to remember. If you buy some thermal epoxy, it comes in a pair of tubes, just like any other epoxy adhesive. Mine also came with a little plastic spoon (for stirring it up) but that's beside the point. Anyway, the whole kit came in a little plastic bag with both tubes and the spoon all together. I used a little bit of the stuff and carefully wiped the ends of both tubes. Use a different piece of paper towel to wipe each tube, as you don't want to contaminate one tube with the other. Then I put everything back in the little plastic bag.andrewwynn said:hey. .in-fact.. if you are only needing to attach a single emitter or three...
