Hogokansatsukan
Has anybody used RCR123A in a Miox Purifier?
Thanks
Thanks
Grox said:cy, how many treatment cycles do you get per battery change? The manufacturers claim 60 per cycle; do you find that this differs?
I've been looking into a uvaquastar or steripen. Cost might be an issue but for peace of mind I might look into the 2 stage filter then uv treat route. Is there any compelling reason to double treat water, when the filter ought to be sufficient?
From the paper it seems that the General Ecology units are removing viruses. The mechanism for removing the viruses is not size exclusion but providing a surface that the viruses will stick to.Have a look at the results GE have published here for virus decontamination: http://www.generalecology.com/techmemocert.htm. I believe that page is a precis of this paper: http://www.generalecology.com/wemedmag.pdf
Based on that paper I think that the GE filters do filter out viruses.
