I was talking to this guy the other day about LED's and I showed him my flashlight (Fenix L2P) and we weer talking about different LED's for EMS work (lights for cars when responding to calls). he works at a large company and is in R&D and told me he would grab me a few emitters.
I didnt think that he was going to but the next day he found me and handed me 40 Lumiled Luxeon Emitter 1W Lambertian's of various colors! needles to say I have a lot to play with now, I just made an order for some misc LEDs aswell.
I've been working with 3500 mcd blue 5mm led's until now. they use like 30mA of current at like 3ish volts. so theres no draw and I can use 1/8 watt ressistors with them. I ran some calculations on these new ones:
Assuming a forward current of 3.7V and a current draw of 350mA we get a wattage of 1.29 WATTS! (WATTS/Voltage = Amps so Volts*Amps = Watts)
Now I ran my LED's specs through an LED calc online (using V=I/R iirc) It tells me i need a 27 Ohm resister capable of 3.3WATTs!?
I could string up 4 25Ohm 5% resistors in parrallel but I dont know if I have that many and with that much load onthe resistors I'll be sucking tons of power and will have to deal with all of that as Heat (I may have to HS the resistor, that seems awfully wasteful)
Now another option (because I only have 12V and 14V PSU's laying around that are capable of an amp or more) would be a small LM317 based circuit to regulate that 12V down to the 3.7V I need. Im not sure if an LM317 can handle an amp (350mA x3 LED's = 1.05A) either way Im going to need to Heatsink that.
I'd like to make a reading lamp with three of the white ones and some night lites with the red ones but Im unsure how to get them the voltage they need as building custom PSU's for them is out of the question for now. Any Idea's for circuit desings that an handle that much power without sucking too much extra current? I suppose I could use a LM317 for every LED and make it three channel, using a pot (or three in this case) would yeild full control without putting much burden on the driver circuits but it seems awfuly wasteful.
