Hi all, I'm new to the forums. I have a question about my leadlight, which I bought and modded some time ago.
I noticed with my first leadlight that the laser would go "dim" after being on for a few seconds, even with fresh batteries. I thought the laser was defective, so I sent it back. The replacement exhibited the same behaviour. Is this normal behavior? (I modded the 2nd laser after verifying the same behaviour, and of course that didn't fix it).
Additionally, I recently noticed that my laser does not put out one beam, but two parallel beams when it goes dim. When viewed from one angle, there are two beams (like the double yellow lines down the middle of a road), and from 90 degrees either way it looks like one solid beam. This splitting is what is causing the dim behaviour I think.
Thanks
Josh
Thanks
Josh
