Hello Brighteyez,
Let's keep the facts straight...
Wayne "discovered" he had a bad batch of CR123 cells when there were problems reported with run times in a SureFire M6. While he was trying to figure out what was going on, several orders were filled. As soon as he was made aware of the problem and the ZTS test results, he pulled those cells from his inventory.
The cells he is selling now have had additional QC at the factory, and he is doing a random check on them more frequently. I have not tested any of these new cells, so can not comment on them. Have you checked out any of this new batch of cells?
I can tell you that the cells that Doug and I have tested have not been the "golden" cells. The golden cells are re markedly better in performance...
When I post results for the Titanium cells, I order a batch of cells and at the same time I have a third party order some cells for me. I then compare the results from the separate orders. This insures that I am not testing "hand picked" cells.
I have sent NewBie a number of these mismatched cells to see if new cells that test low on the ZTS tester will vent. NewBie is observing some very interesting results. I hope the NewBie will be able to answer some questions about the differences in brands as a result of his testing.
I frequently get asked what CR123 battery is the best. I respond that I have been getting the most consistent results from the Sanyo cells, followed closely by the Duracell cells. However, there are reports of counterfeit cells, so you have to be careful.
I hear back that they were hoping for a cheaper recommendation. At this point I point out that the Titanium and BatteryStation cells are only $1 each and the discussion is ready to end there. I go on to explain that there have been some consistency issues, but they are working on taking care of them. With this information, the discussion usually ends. I don't have time to discuss the middle priced cells, i.e. SureFire, Streamlight, Panasonic, Toshiba, Energizer, Maxell, and so on.
The real question should be "What is the difference between a $2.50 cell and a $1.75 cell and a $1.00 cell?" The ongoing testing should help us understand and answer this question.
Tom
