HDS Systems
Results 1 to 12 of 12
Thread: Battery Sizes.....
    Jan 2001
    SoCal
    Default Battery Sizes.....
    Anyone have a list? Example: What is the name of the battery that is the size of 2 123's?
    Flashaholic* Ra's Avatar
    Jul 2004
    The Netherlands
    Thinking Re: Battery Sizes.....
    Sorry, I don't have a list...
    But the popular 18650-cell comes real close to 2 123's..
    TIP: Ask AW.. the battery seller on CPF !!
    The proof of the existence of intelligent extra terrestrial life lies in the fact that they didn't contact us yet...
    Maxablaster MB Beamshots 10Watt Mini HID SSC Microblaster!
    Default Re: Battery Sizes.....
    This List from the CPF Wiki may help
    He who laughs last, thinks slowest
    Quote Originally Posted by Doug
    I want to say it's called a 223, but I'm not sure.
    Jul 2004
    The Netherlands
    Ohgeez Re: Battery Sizes.....
    Didn't know about that list...
    according to that list the 17680 and 17670 are 2xCR123 in size...
    Never too old to learn...
    Ra.
    Flashaholic* Long John's Avatar
    Mar 2006
    Spain, near Cadiz
    I don't know about the 123's. But for the others:
    The first two numbers are the diameter, for example 18650=18 mm,
    the next two are the lenght=65mm and the 0 for round.
    So the 18650 should be a little bigger(1mm) than the 17670.
    Best regards
    ____
    Tom
    Jun 2006
    Pa, U.S.
    cr123a cells are actually something like 16340? I'm pretty sure. AW has it in his battery sale thread in the dealer's section if you REALLY want to know.
    Silver Moderator
    SilverFox's Avatar
    Jan 2003
    Bellingham WA
    The 123A nomenclature indicates that it is 1 cell that is 2/3 the length of an A cell. A cells are around 50 mm in length and are 17 mm in diameter and are round. That means that a 123A cell should be similar to a 17340 ( I believe it actually works out to 33.33 mm in length). In theory, two of these would be a 17670.
    Tom
    Behind every Great man there's always a woman rolling her eyes...
    Most batteries don't die - they are tortured to near death, then murdered...
    Jan 2001
    SoCal
    Ok, great guys, so, 17650/17670 it sounds like... but what about the voltage, I assume it should be 2x3.7=7.2, right? Also, what chargers are capable of charging CR2's, 123's and theses 17650/17670's? Thanks!
    Silver Moderator
    SilverFox's Avatar
    Jan 2003
    Bellingham WA
    Hello Doug,
    The 17670 is the size of one Li-Ion battery. It will have a nominal voltage of 3.7 volts and be charged up to a maximum voltage of 4.2 volts. This single battery just happens to be the size of two CR123A cells in length.
    Tom
    Jan 2001
    SoCal
    Oh! So, you loose voltage, so, I am better off using 2 RCR123's, to get the higher voltage, eh? As long as they are protected, right? No issues with using 2 RCR123's, right? What about theses 900ma ones, any issues with them?
    Silver Moderator
    SilverFox's Avatar
    Jan 2003
    Bellingham WA
    Hello Doug,
    You have to determine if your light can handle higher voltages. Sometimes they burn out because they aren't designed to handle the higher voltages.
    Keep in mind that 2 CR123A cells give you around 6+ volts, where as 2 R-CR123A cells come off the charger at 8+ volts.
    For example, the SureFire L4, and perhaps the U2 as well, can not handle the extra voltage, however they work just fine on one cell.
    Tom
