NightShift
For LED purposes...does anyone know how electronic flashers work? I thought they werent supposed to rely on load. I had bought a variable load electronic flasher in hope to get a more controlled "on/off" equal interval than a thermal flasher and so i can hear the distinct "click"...also in case I ever wanted to convert to LEDs.
Well it doesnt have the interval i was hoping for although it has the click I can hear. It still seems to rely on load because it flashes faster with a smaller load and slower with a heavier load.
But when I tried hooking a 12v LED array to it (0.5 amp load on bright), it lights dimly but not enough load to make it flash. I also tried in addition, a 6v LED array with resistors and it still didnt make it flash, although with an incandescent it does.
So any explanation for this? I thought electronic flashers are supposed to work with LEDs as opposed to thermal?
Update: If i add a 5W 27/30ohm resistor, it flashes perfectly at a perfect interval, but a 16ohm makes it stay on longer than off which is how i dont like it and how it currently acts in my car.
