Thanks for considering about it Jdriller hehe
In all honesty though, i don't know *for sure* whether a top shelf ROP will match a good M@g85, which is why i added IMHO to the end of my previous post.
However, here's some info.
I own a custom ROP and a G&P R500. The R500 is known to put out around 425 lumens (from comparisons between SF M6 etc) and in my lightbox, my R500 fully charged equates to 416 lumens.
My ROP in ceiling bounce and lightbox tests, gives more than double the output of the R500. So that's...say 416 x 2 = 832... and that's only double. My ROP outputs more than double in ceiling and lightbox tests.
Anyways, here's the data
R500 in lightbox = 257
My ROP = 738 (highest ever, havn't been able to reproduce this number). However, i've consistently obtained ~680.
(The lightbox, for incan lights...to convert the number to approximate lumens, use a multiplier of 1.62)
A top shelf M@g85 can give 50,000 lux with a LOP reflector too IIRC. I've measured my ROP at 50,000+ lux before.
I can tell you this for sure though. I have a 2D ROP with 6 CBP1650s and a fully switched fixed and the tailcap spring has been modified for low resistance and this light measures around ~700 lumens in my lightbox which is on par for a 2D ROP build after fixing the resistance...my custom ROP completely eats the 2D ROP. No contest at all.
