flashlightlens
I recently sent a few lenses out to Roy in order to test the light transmission compared to stock poly. Here's what he measured:
The test were performed using an un-compensated photocell and a multimeter. The numbers are the mA measured of the output of the photocell.
For the 52mm UCL lens, a DD Maglight with a LED for the light source was used.
The average of 10 samples with and without the lens were measured. 468.6mA with no lens and 465.7mA with the coated lens. Transmission was 0.9936 or 99.36%.
The average of 10 samples with and without the OEM plastic lens were measured. 468.1mA with no lens and 428.1mA with the OEM lens. Transmission was 0.9145 or 91.45%.
The Borofloat glass lens for the AA Minimag was tested in a similar manner but using only 5 samples. The light source was a AA Minimag with the Opalec led conversion.
526.2mA with the glass lens and 562.4mA without the lens giving a transmission of 0.9356 or 93.56%.
514.2mA with the OEM lens and 555.8mA without the lens giving a transmission of 0.9252 or 92.52%.
These results reinforce the claim of about an 8% increase in brightness when using the UCL lens and 1% with the Borofloat.
