jar3ds said:
What Would A Fan Do Inside a Sealed Flashlight?
Nothing good!
Re: heat pipes. They take heat in on one side and spread it evenly across the whole pipe. So the idea is that at any given time, the whole pipe is the same temperature as the hot input end.
This is good because while aluminum conducts heat well, it doesn't do it nearly as well as that. If you look at a thermal image of a flashlight-size chunk of aluminum with a heat source on it, you'll see that the temp drops significantly as you move away from the heat source. For instance, it might be 10 degrees lower every centimeter. That is why useful heatsinks don't have super tall fins -- the effectiveness of the extra length drops significantly the more length you add. So you'll notice that most every solid heatsink will have fins no longer than a couple cm.
That's where heat pipes come in. If your application needs more heat sinking than it can get from that fixed area of short fins, you plug a heat pipe into the equation and suddenly you can transfer this heat to MORE short fins than before. That's the key. Heat pipes don't directly let you spit more heat into the air. They just let you shunt some heat to a place where you have more fins.
To illustrate, see the best performance CPU heatsink today:
http://www.overclockers.com/articles1329/ It uses heat pipes to spread heat from one small source to a much larger area where it can be wicked away. This type of heatsink is heat and shoulders beyond the best traditional heatsinks from just a few years ago.
Fun bonus: note how there are no fins on the base plate. This particular manufacturer actually started building these heatpipe heatsinks with fins there. See the left part here:
http://www.ap0calypse.com/scottrempel/si120/si12002.jpg But under testing you actually see that the extra fins either make ZERO difference, or so little difference that they aren't worth the extra penny of machining. Thus you see the newer generation of parts above and on the right of that last image. No fins on the base because it's not very hot -- the heatpipes THAT effective at removing heat from the base.
So here's the flashlight connection. A hot flashlight will basically have a really hot head, and then everything else (the body) is just a minor bonus. The dissipation performance of the head makes or breaks the system. I know from experience with my U2 on high that about an inch of head length gets really hot, and the rest significantly cooler.
So if you want to increase the cooling performance of a flashlight with heat pipes, you want to build heatpipes into the flashlight in such a way that it shunts heat from the heat to somewhere else with more dissipation performance.
My thoughts on a heatpipe design are as follows. Unless you plan to have a stack of fins on the tail, running a heatpipe to the tail won't do much of anything. And I don't really see a finned tail cap working out well. Better to just increase the fin area on the head and work through the heat pains.
So what would I do instead? I'd use the aluminum body and knurling to my advantage. I'd run a heatpipe or two from the head down inside of either side of the sufficently thick and well-knurled body.
A pretty massive undertaking for a custom light. And for questionable benefit -- LEDs are getting cooler and more powerful every year. In 10 years the thought of using heatpipes in a flashlight will be ridiculous. Even now it is overkill only necessary for use in massive LED arrays.
Conclusion: A fun idea, but probably impractical and unnecessary
