Hi there, as the title say i need to decrease the output on my laser.
Specs:
- Green Laser sight unit
- Wavelength: 532nm
- Max output: 50mw
- Length: 11 cm
- Beam Diameter : 1.2 mm
- Beam Range : 25 miles
- Windage & Elevation Adjustment
- Material: Aluminium metal
- Use CR123A 3V Lithium Battery
this is the laser i just bought.
i do not know much about lasers yet but i was told that 50mW was harmful to the eye, and would burn it in ½ a second.
if anyone knows anything about decreasing the output or any other ways to make it safer.
I am most interested.
hobe you can help.
Specs:
- Wavelength: 532nm
- Max output: 50mw
- Length: 11 cm
hobe you can help.
