Just received an assortment of the Luxeon white LED's (stars and emitters) and had some basic questions.
I want to use a couple of the emitters on a PCB and was wondering if someone can give me a brand name and part number on a suitable epoxy to use.
But first of all, let me understand....
Are the slugs supposed to be electrically isolated from not only the heatsink but from each other as well? (Some of the data gives me that impression but I can't understand why....unless the cathode ties to the slug or something).
What I'd like to do is make a simple "sandwich" of regular FR4 PCB material on top and some 090 aluminum sheet on the back....maybe a 1" by 5" arrangement or so.
Why can't I just mount the emitters on the top layer of the pcb with all the traces and circuitry on top and have a .375" hole behind the emitter. (Of course, completely isolating the cathode and anode in the process).
Then I could simply put the epoxy in the .375" hole and mount my aluminum to the backside of the pcb....I could use machine screws as well to tighten my "sandwich".
Is there an epoxy someone can suggest? (Is there anything that can simply air cure?) I'll probably run these at slighty lower than rated maximum.
Thanks very much.
Thanks very much.
