AvroArrow
I just received a TerraLUX 1W UV LED drop-in (395nm CREE) and found out that it's not the correct wavelength for lighting up what I wanted (the yellow/red UV security feature on new Canadian bills).
I had bought 10 UV LEDs (360nm) (specs here: http://www.thefoxgroupinc.com/p1-1.html, quick specs: If=20mA typical (max=30mA), Vf=3.8V typical (3.6-4.5V)) waaay back in a group buy (it was so long ago that I can't even find the thread anymore, and "UV" isn't long enough of a search string either) and swapped one into the infamous $6 Dorcy 1AAA LED. It worked, but was kinda weak (obviously), which was what prompted me to jump on the TerraLUX/CREE UV drop-in.
Since that didn't work out like I expected, I'm looking for a good multi-LED host to swap in the remaining LEDs (9, or 10 if I scavange the Dorcy) into, which will hopefully work out better. Anyone know of a good host (10 LEDs or less) that's relatively easy to mod? I don't really want to spend $39 on an Inova X5-UV and try to tear it apart.
I've found a couple like this cheapie at Lighthound though: http://www.lighthound.com/sales/multi-led_flashlights.htm It looks promising (and cheap ), except I'm not sure how well it re-assembles after disassembly. Any suggestions?
