I'd like to start a 532nm laser project myself, although I will really need the help of the forum to successfully complete I believe. I hope some of you would be willing to help here, as trying to put this together alone I am really in the dark.
I have been away from the laser scene for just a bit, and really have no clue as to what is available these days as far as diodes and their current supplier pricing - as well as crystal sets.
I would like to do something >200mw, and if I can afford to put it together, closer to 400-500mw.
The setup of the laser would be in as small of a package as possible, with external battery on a remote cord. I'm doing this to hopefully be able to build cheaper, as I won't need specialized and small parts for a pointer body, also limiting potential output.
I would like to start with the drive board, diode, and heat sink. I will then move on to crystals and optics to see what overall package size I will be working towards requiring.
With that being said, I have a few questions I hope you guys don't mind helping me with...I'll try not to ask too many at once.
For starters, I assume before buying a diode I should price everything and see what output range my wallet is really capable of achieving. I realize 9mm 1.5w Sony diodes are the most readily used today for higher outputs. What is theoretical maximum 532nm output from a diode of this size? I'm really just unsure if I should take a stab with this diode, or possibly find something in the range of >2w if possible.
My next few questions are, and I'll leave them my final for now, what specific function does the drive board have? I assume it regulates and ramps power up upon each activation of coarse to ease the diode's use. Will it be possible to attain a drive board from some other electronic device once I decide upon my diode output?
Thanks for any info which can be provided on this topic.
