batman
Hey everyone,
Does anyone know just how many lumens those aircraft landing lights are on the 737s,747s, etc?
batman
batman
batman said:Hey everyone,
batman
XeRay said:either 450 or 600 watt. and ~ 5000 or 7000 or so lumens respectively.
Starlight said:We have hand held spotlights using the Q4559X. It is rated at 600W, 28v and 770,000 CP. It's called the Larry12k.
Orbit said:747's 737's and most other commercial airliners do use HID. What they use exaclty i can't tell you, but search google i'm sure you'll come up with something.
ernsanada said:glass: PAR46
XeRay said:Boeing and Airbus have only VERY recently begun to use HID on factory new aircraft. They are using 50 watt HID maximum so far.
The vast majority of large commercial aircraft still use incandescents. The Canadair CRJ-700 series commuter jets are the only ones using HID for a few years.
35 watt HID is equal to 200-250 watt incan. 50 watt HID is about equal to 450 watt incan. in terms of lumens. A 75 watt HID will outperform (lumens) a 600 watt incan with same reflector size.
Goodrich is the primary supplier at this point, we are working on that.
Aviation is very slow to move into new technology because of the time and cost involved to TSO the product and to change the "Type Certificate" in new manufacturing. Also STC's are time consuming and expensive as well for these aircraft. For airliners DO-160 testing which is very expensive and takes a lot of time would be required.
larryk said:I own the Barnburner and it is a great spotlight and I am very happy with it, but my larryK14 using a slightly overdriven 600 watt Q4559X lamp produces twice the lumens of my Barnburner. Maybe it's because of the 8 inch reflector ?
scott.cr said:FWIW, you can calculate the diameter of the sealed beam assembly by looking at its "PAR" number... simply divide by eight. So a PAR46 would be 5.75 inches. The largest the PARs come in, AFAIK, is PAR64 and I've seen the commonly-available ones as high as 600 watts. Lamp lifespan is short, so I suspect these filaments are being driven pretty hard. Most run on aircraft voltages of 28 volts, but I've seen 500 watt versions in 12 volt.
XeRay said:35 watt HID is equal to 200-250 watt incan. 50 watt HID is about equal to 450 watt incan. in terms of lumens. A 75 watt HID will outperform (lumens) a 600 watt incan with same reflector size.
BVH said:Geeze, Lux, now I GOTTA have one. Mad Max, sent you a PM a while ago. Lux, does your arm get thrown back when you light it off?
