Imalent
Results 1 to 15 of 15
Thread: What is G10 in reference to knife handles?
    Sep 2006
    toronto Canada
    Default What is G10 in reference to knife handles?
    I was looking through the catalogue for the store I buy knives from and noticed knives by kershaw and spyderco jump in price quite a bit when they have G10 handles or G10 inserts. What is this stuff?
    Default Re: What is G10 in reference to knife handles?
    G10 laminate grades are produced by inserting continuous glass woven fabric impregnated with an epoxy resin binder while forming the sheet under high pressure. This material is used extensively in the electronics industry because its water absorption is extremely minimal and the G10 line of materials is not electrically conductive. The G10 is most commonly used in PCB (Printed Circuit Boards) applications. G10 exhibits superior mechanical and dimensional stability and doesn't shrink. Temperature ratings of 180 degrees C. In addition to these properties, G10 has excellent dielectric loss properties, and great electrical strength. G10 is also known as Micarta and Garolite and can be used for structural supports, buss bars, mechanical insulation, gears, test fixtures, washers, spacers and tight tolerance machined parts for electromechanical assemblies.
    Flashaholic* D@rk Messenger's Avatar
    Jan 2006
    toronto, canada
    Quote Originally Posted by waynejitsu
    Isn't micarta resin impregnated linen?
    All started with a streamlight keymate...CPF, NOW LOOK WHAT YOU HAVE DONE!...embarking on the journey for a real light...better than surefire ...making pathetic attempt searching for the ultimate aa cough-cree cough cough ion cough
    Jun 2006
    TN
    and the textured version(not polished) adds a great grippy feeling to the G-10 leek(my favorite) and the avalanche(2nd)
    both great knives.
    Dec 2003
    North East Arkansas
    Micarta can be linen or paper if I recall.
    G10 can be hazardous to work with so I would not modify a knife handle using it without extra care...ventilation and a mask so you do not inhale it.
    Topper
    Nov 2002
    Michigan, USA
    G-10 handles are nice. Most of my EDC knives are G-10 with the exception of my small Sebbie. The G-10 is light weight, strong and grippy.
    Life is a journey, not a destination... Tread lightly and leave only footprints behind.
    Sep 2006
    toronto Canada
    thanks guys, that pretty much answers my questions. Pumaman, It is the G10 leek I am looking at, it goes from $57 to $95 (CDN) from stainless to G10 handle.
    Is it worth it?
    Nov 2004
    DFW, TX
    The G10 Leek also has different blade material.
    To answer a previous question, Micarta and G10 are very similar in properties and how they work for knife scales. My Leek has polished G10 and looks very similar to some of my other knives with polished Micarta. I have another knife with rough finish G10 that looks similar to some rough finish Micarta that I have. I think G10 is probably a less expensive material than Micarta. I bought the G10 Leek because I thought it would maintain its appearance better with a lot of carry, where the stainless or anodized Leeks would probably show wear and scratches easier.
    Micarta can be made from paper, linen, or canvas. The paper micarta has almost no grain, linen micarta has a little and can still be fairly smooth when polished, canvas micarta usually has a little roughness even when polished, but is normally not polished and left rough for more friction.
    Pel. M6 LED, SL TL-2 LED, TL-3 Xenon, Scorpion, Inova X5, SharperImage Luxeon, Gerber Infinity, Petzl Tikka, 2C Mag 3x123 KPR112, 2D Mag 7xAA KPR118, Nuwai QIII, TM115, TM311, 3rd_shift Luxeon 3C Magmod, Solitaire Luxeon, MiniMag MJLED,Mag85, MagLed 2D.
    Flashaholic* benchmade_boy's Avatar
    Apr 2006
    not far enough away
    one thing about g-10 is that it dosent get cold in the winter and hot in the summer like aluminum. I love it on the older benchmade nimravus i dont know why they changed to alumunum but it does look better.
    Jun 2006
    TN
    Quote Originally Posted by brightb
    Is it worth it?
    Bought the standard leek first(around $37) then went to Smoky Mnt. Knife Works and spent a couple hours checking out many options from many brands. Left with a G-10 Leek($72 i think) and sold the original leek to a friend at work. Then bought the bigger avalanche(G-10) online as a backup carry. The thickness and texture adds measurable confidence in the grip on both. Thought I had lost the leek a couple weeks ago and was pissed, but ready to buy another. would only buy the regular if you needed the thinnest knife possible.
    short answer: completely worth it
    If you want to try out a G10 handled knife check out the new models from the Spyderco Bryd line. For less than $25 you can get the Meadlowlark (Blade Magazine's best buy of the year for 2006) or Cara Cara.
    https://edcdepot.com/merchantmanager...roducts_id=118
    www.EDCdepot.com Please use the coupon code CPF to receive your 5% discount on all purchases. If we carry it, so should you. FREE Spy Capsule with every order.
    Flashaholic Danbo's Avatar
    Mar 2005
    Elizabethtown, KY
    G10 on a knife handle = a secure, good feeling knife handle that you never have to worry about. I like it quite a bit for my users.
    Sadness is just another word for not enough coffee.
    Flashaholic* PhotonBoy's Avatar
    Mar 2003
    Annapolis Valley, Nova Scotia, Canada http://tinyurl.com/8zu5t
    I carry a Gerber LST II with some kind of plastic/glass reinforced handle and I appreciate its light weight. I find an all-metal knife a real burden in the pocket.
    Flashaholic* MoonRise's Avatar
    Feb 2004
    NJ
    G10 is a glass-reinforced resin material. Originally used as a base for circuit boards, and then used for handles or other 'plastic' parts needing some of its properties.
    Micarta is a resin material reinforced with layers of 'fiber', most often paper, linen or canvas.
    They are different materials, that can be used in sometimes similar uses.
    Mike
    EDC: HDS U60GT with RCR123, guilt-free lumens!
    old EDC: ARC4+, semi-tactical, force primary, primary=10, secondary=4
    Life is too short for ugly or cheap.
    Unenlightened
    Oct 2012
    Does anyone know where I could purchase a thin sheet (or strips) of G10 with peel-off adhesive backing?
    I would love to put this stuff on my cell phone to improve the grip.
    Thanks.
