It's a very specific but minor problem I have regarding my SW02 and its use with a KL5 on a C3 body with 17670 li-ion and a dummy battery. It's minor but very irritating especially since the SW02 is not a cheap tailcap.
When I use both the the standard lock-out tailcap and the Z48, the KL5 seems to put out just a slight bit more light than when I use my SW02.
The SW02 and LOTC are some of my oldest tailcaps. Though only about 6 months old, they've been used heavily in many SureFire bodies. The Z48 is quite new. Measuring the resistance between the tailcap spring and contact 'tabs', the Z48 has a resistance of about 0.8 ohm while the SW02 has a resistance of 1.0 ohm. Could this 0.2 ohm difference really be responsible for the slight dimness?
I've also noticed that the KL5 is quite sensitive to the position of the dummy battery in the C3 body. If placed in front of the 17670, the KL5 will be more likely to flicker or dim-especially when the battery is starting to empty. Another resistance-related problem?
