Hi, I am going to share some experiences that I've had with various lasers which I have currently in my possession. I've got a number of lasers, but I'll only cover the dpss ones here.
300mw 532nm wall powered laser - purchased from alltech-solutions on ebay - this laser works well - has larger divergence than some of the pointers though. works well with modulation, measured output of 350mw. Very little IR leakage. This unit takes a bit of time after power on to create a beam, but I'm sure that's because of its start up sequence - its longer than the CDRH time required. 1 item purchased, and it was good.
100mw 532nm wall powered laser - purchased from aixiz_lasers on ebay - works well, has reasonably good divergence, beam can be shut off by turning end. 125mw output, very little IR leakage. Some issues with fast modulation, but the TTL input works correctly. I've purchased numerous items from this vendor, and shipping and product have always been good.
50mw 473nm wall powered laser - purchased from extremelasers - good, well built unit, >50mw output (I don't have accurate calibration here) good divergence, beam can be shut off easily, quick shipping.
PORTABLES
Leadlight from Atlasnova - many lasers purchased from abeland1 on ebay, others directly from atlasnova - all lasers have been good, with very low divergence. Fast shipping. Came with yellow sticky with actual laser power output which was within 1% of my reading. Very good customer service.
Mystery laser from ebay - discounttown. Comes on dimly initially, has terrible divergence, but puts out 15mw. Not great, but not bad either for the price. Took a while to arrive.
PPL-260 from Optotronics - quick shipping, stable output. Comes with certificate showing power output, which matches my measurements. Has shutter for output. low divergence, can be easily coupled to a melles-griot collimator for even better performance. Very good customer service.
I would be interested in the experiences of other people with their vendors and lasers.
Thanks,
--Ted.
PORTABLES
Thanks,
--Ted.
