Olight - S1 - MINI
Results 1 to 20 of 20
Thread: Arc AAA mod with Cree XR-E vs. LOP SE
    Flashaholic* MillerMods's Avatar
    Mar 2005
    Columbus, Ohio
    Default Arc AAA mod with Cree XR-E vs. LOP SE
    Here are some shot's comparing an LOP SE on high w/ an SV1H Lux I (Left), the Cree monster at 1 watt or ~320mA (center), and one of my Luxeon Arc mods w/ an SWOH Lux I driven at 1.5 watts or 470mA (right). The lights are about 1 foot from the wall.
    Here's some photo's of my first trial runs. Unfortunately I'm not good with my camera and I didn't figure out how to turn off the auto adjustment for exposure. So the difference for the different drive levels isn't as obvious in the photo's as it actually is in person.
    LOP SE on high (stock driver w/ an SV1H Lux I) vs. Arc AAA head w/ Cree XR-E (P3 brightness). The lights are about 6 feet from the wall.
    Arc Cree @ 180mA
    Arc Cree @ 240mA
    Arc Cree @ 350mA
    I had another photo here but I removed it because it gave the the illusion that the reflector was way off center, but it was because the very edge of the polished reflector is at a different angle. The stock reflector is a little larger in diameter than my cut for the new reflector.
    Sign-up list for the MillerMods high power Arc AAA Cree XR-E mod is here
    Aug 2004
    Sydney, Australia
    Default Re: Arc AAA mod with Cree XR-E vs. LOP SE
    Good job as usual MM
    Was it easy getting the LED in?
    Any tips for others on how to solder the little buggers?
    Thanks a lot- good luck with a new MM line!
    Kind Regards
    David
    Mar 2005
    Columbus, Ohio
    It's a very tedious process because the pads left on the Cree after being cut down are very small and requires good soldering skills and a steady hand to get the wires well attached.
    Sep 2006
    Brisbane, Great Southern Land
    Good job mate. I understand you'll be doing a bit more testing, but when are you lookin at putting the cree arc AAA into production?
    Flashaholic* TENMMIKE's Avatar
    Jan 2006
    puyallup WA.
    Flashaholic* GhostReaction's Avatar
    Aug 2005
    Singapore
    how about a Cree in one of those LOP se. More space to work around it.
    Lights were once incandescent. And halogen bulb were great
    Jul 2002
    Nashville, TN
    looks promising, anxiously awaiting the sales thread for these...
    -Eritt
    And God said, Let there be light: and there was light. And God saw the light, that it was good: ----The Big Guy
    Flashaholic* Manzerick's Avatar
    Dec 2004
    Boston, Massachusetts
    that's some good power in a small package!
    Everything that was true a short while ago has changed...
    Flashaholic* coyote's Avatar
    Dec 2002
    eastern oregon
    sign me up for the MM Arc XR-E !
    Flashaholic* AlexGT's Avatar
    Jan 2001
    Houston, Texas
    Great mods!
    Do you think those CREE leds can fit on a L2P or L2T? Any idea as to how the beam / reflector combination would look?
    Thanks!
    Banned x2x3x2's Avatar
    Jun 2003
    why XR-E in the Arc instead of the L0P?
    Mar 2005
    Kent, England
    Wow! I am definitely in for one of these.
    Marc
    Mar 2005
    Columbus, Ohio
    Quote Originally Posted by x2x3x2
    The LOP reflector is all wrong for the Cree, Trust me, I tried. The reflector I cut on the Arc is 8mm deep. This Mod is really unreal in person. It has much more throw than my Luxeon version and puts out alot more light too.
    I updated the original post with some better pictures of comparisons.
    Jul 2004
    Sweden
    What kind of run time can one expect from this, roughly. I'd calculate it myself but I sorta suck at that stuff since I've never dealt with it.
    Mar 2005
    Columbus, Ohio
    Quote Originally Posted by Robban
    This 1 watt version will give 30-55 minutes (depending on how you use it) from a Sayno 900mA NiMH cell, and 3-6 hours on the low setting depending on what drive I set it to.
    When the light is room temp. it draws about 1 amp and when it get to it's peak operating temp it draws 1.5 amps from the cell because it compensates for the loss of efficiency when warm. In other words, short uses will yield longer accumilative runtimes.
    Flashaholic cloud's Avatar
    Jul 2006
    UK
    nice work there MM
    cloud
    Apr 2005
    Connecticut
    looks good.
    Your beamshot states P3 was used which from your post has a WC tint. Have you done anything with the P2 brightness WG tint emitters yet and if so how is the tint?
    Have you any info on what the xre beam is like in an unmodified arc aaa reflector?
    Brian
    Mar 2005
    Columbus, Ohio
    Quote Originally Posted by bwm
    I haven't really done much with the P2's yet except destroy a few and sell a few. I think I have 1 left.
    A big ugly donut hole.
    Mar 2005
    Columbus, Ohio
    The new sign-up thread is here
    **Do Not Feed The Vegan**
    jch79's Avatar
    On the asphalt.
    Way to go Eric I had a feeling you were going to be able to do it!
    john
