PEAK
Page 1 of 9 12345678 ... LastLast
Results 1 to 30 of 241
Thread: TnC SF-Series parts/lights and the new TnC online store
    Default TnC SF-Series parts/lights and the new TnC online store
    I'm selling some bare aluminum TnC SF-Series parts and lights. To attempt to make these sales easier and to prevent clogging CPF with a bunch of photos I've listed the items on the new TnC Products store for custom lights/parts. However as can be the case in trying to make things easier, the opposite may occur so please be patient. Please post questions, special requests, and follow up with orders in this thread or on TnC Forums.
    Soon I will have a specifications and explanation thread for the TnC SF-Series lights on TnC Forums where I can sticky the thread. In brief these lights are E series tail compatible to use your favorite tail cap. The current power packs allow the use of the TnC SF 20mm head with McR-20 reflector, the 27mm TnC SF head with the McR 27L reflector, and with the three VIP heads, including the 3" BBH for the ultimate in throw. Future power packs will be built to accommodate further head configurations. There will soon be released a small run of power packs to fit the Aleph heads, however these will not work with the Aleph LEs, rather they will work with the TnC canisters as shown below.
    Below you see the E series TnC SF tail, 18650 tube, power pack, canister holding the converter and emitter which is reverse threaded into the power pack, and the 20mm head w/bezel. Missing from the photo are the o-rings, reflector, lens and tail cap assembly. These tail caps are available as a clicky with the Mclicky switch and rubber boot, or as a single stage twisty.
    Below is a 20mm TnC SF light with a 18650 tube and a short (protruding switch/boot) tail cap.
    Below are the available tube sizes: CR2, CR123, 18500, AA and 18650. There are canisters available to nicely drive LEDs on AA batteries.
    TnC SF-Series lights come in limited quantities of bare aluminum, black HA and Natural HA. Below is a NAT 27mm TnC SF head with the 27L reflector.
    Cree and Seoul as well as other custom builds of the canisters are available as well.
    Banned Regentag's Avatar
    Jun 2005
    Mineshaft
    Party Re: TnC SF-Series bare aluminum parts/lights and new TnC online store
    Wow! Chris's work is top notch - I've been hooked on TnC since I scored my first Lith-Lux V.
    The SF-Series really brings new meaning to the "LEGO-Light" concept.
    These bare Alu pieces are beeeeeautiful, and will go well with some other SF stuff in my parts bin (a/k/a shoebox).
    Put me down for (I think I got the prices right):
    $31.50 tube CR123 (bare)
    $33.00 protruding twisty (bare)
    $29.50 power pack (bare)
    $49.50 20mm head (bare)
    $33.50 tube 18500 (HA-Nat)
    PayPal incoming... And let's talk about a Pop2 Lux V Lava Lamp
    Crees? We don't need no stinkin' Crees!
    Flashaholic* ianb's Avatar
    Feb 2004
    Herts, England
    Default Re: TnC SF-Series bare aluminum parts/lights and new TnC online store
    Bogus1 for a Lavalamp (#1 from the photo's)
    thanks, Ian
    Inova 24/7 | Princeton Tec Impact XL | SL Propoly 4AA | Al PD UV1J *found it!* | Mag-P4 | M273 | C45 Aleph (pending LE) | Mule miser | Xeray 50| Stenlight S7
    Nov 2004
    Huntsville, TX
    So are these Surefire E-series compatable? Will the 18650 body just hook right up to my Aleph/Surefire stuff?
    Josh
    No 18mm tube with an E series tail will hook straight up to a Surefire E series or Aleph head because the threaded area at the head would be too thin and would be weak. You need a split body tube to have an 18mm battery work with an E series if it also has an E series tail because you need to load the wide battery somewhere. I have a small run of Aleph compatible power packs that will fit Aleph heads, but these will not fit Surefire E series heads because these power packs are made to use the TnC canisters instead of the Aleph LEs. You can think of the power packs as canister holders and adaptors all in one and yes in the future there will be several varieties to run a large number of different heads on the TnC SF-Series lights. I do intend to have a two part tube that will mate directly to Aleph heads with Aleph LEs, as well as directly to the Surefire E series heads.
    Quote Originally Posted by trivergata
    Josh
    Jun 2005
    Mineshaft
    Got my 'goodie bag' today ... top notch!
    Cheers,
    Feb 2004
    Herts, England
    Thanks Bogus1, I just got my new Lava Lamp today, its awesome, the throw of the McR-27 is excellent! I will post a pic later, I love the annodsing too, its my first light which is made to look cool as well as work well
    thanks, Ian
    I've added or restocked the items below to the TnC Online Store. I thought I'd post because several of the new items have already almost sold out.
    TnC SF-Protruding Twisty Tail Cap (HA-Natural)
    TnC SF-CR2 Tubes (HA-Black)
    TnC SF-20mm Heads (HA-Black)
    TnC SF-27mm Heads (HA-Natural)
    TnC SF-27mm Heads (HA-Black)
    TnC Ti-Bezels for 27mm Heads
    TnC Canister keys
    TnC 27mm Bezel Key
    Kroll Switches
    McClicky Switches and boots
    CO-30 Holster Clip on Holster for Hyper-Lux III size lights
    CO-137 Holster Clip on Holster for AA size lights 6
    400mA Buck/Boost 400mA Buck/Boost (SX0H) 1.2v - 9v Max complete canister LEs for Key-Lux AA and TnC SF-Series lights
    Default Re: TnC SF-Series parts/lights and the new TnC online store
    I've added the items below to the TnC Online Store. Some of these are in short supply.
    TnC SF Black HA power packs
    TnC SF Natural HA power packs
    TnC SF Black Aleph head (only) compatible power packs
    TnC SF Natural Aleph head (only) compatible power packs
    TnC SF bare Aleph head (only) compatible power packs
    TnC SF Black HA protruding clicky tail caps (E-series)
    TnC SF NAT HA protruding clicky tail caps (E-series)
    TnC SF Recessed NAT clicky tails (E-series)
    TnC SF Recessed Black clicky tails (E-series)
    Cree (and Luxeon) compatible TnC cans and O-ring spacers (for focal adjustment)
    I'll try to get some photos up for these parts today/tonight.
    Thanks for looking.
    Hi Eric,
    I'd like the following;
    2 x NAT TnC SF power packs for TnC SF-Series heads
    2x NAT TnC SF-Series recessed clicky tails
    1x bezel key
    1x canister key
    2x cree canisters
    Thanks,
    TB
    karlthev's Avatar
    Nov 2004
    Pennsylvania
    I gotta read this a bit more Eric. TNc stuff some of the very best from my perspective. "I'll be back".
    Karl
    May 2002
    Maui
    Nice looking parts!
    Feb 2003
    Northwest Indiana
    Are there pics on the site? I can't see the photos of the new parts.
    Li-ON Heart #126, VIP!!,Blaster III, Pal Light, ARC LSL, lots of non led!
    Quote Originally Posted by McGizmo
    Nice looking parts!
    Thanks Don, that means a lot coming from you! Of course it doesn't hurt we use the best off the shelf parts as well such as your reflectors and switches
    Zman, I'll try to get the pics up in the next day or so. Things have become really busy and until I get the satellite working I'm relying on dail up.
    Flashaholic* skalomax's Avatar
    Apr 2006
    Southern California
    can you please send me a PM when you accept Credit Cards?
    Thanks
    I miss my Milkmods.
    Flashaholic* vacuum3d's Avatar
    Feb 2004
    Bay Area, CA
    I'll have to stick with my original order because funds running low again ;(
    1 x TnC canister for mounting a Cree or Luxeon LED and converter 18.00
    1 x Rubber Switch Boot 5.00
    1 x TnC SF Natural HA power pack 30.50
    2 x TnC SF Natural HA recessed clicky tail cap 72.00
    Total = 125.50
    Thx,
    ernest
    Feb 2004
    Bay Area, CA
    Eric,
    Can you post a picture of the "TnC SF power pack to fit Aleph heads". I would like to see how it looks when installed.
    thx,
    ernest
    The package arrived today Eric...
    I assembled a whole light, without a LE, just to see how it will look...It's really a high quality set-up, the fit and finish of all the parts I ordered is superb. I thought you may have sent me the wrong cell tubes, the 18650 tube blends perfectly with the head, and the switch...the O.D. of the 18650 tube had me fooled into thinking you've sent 123a x2 cell tubes...I grabbed a 18650 off the shelf, and sure enough, it fits perfectly.
    I would also like to see a completed Cree LE, if possible...Those little cans are so nicely made I don't want to screw them up, by doing something incorrectly.
    Thanks,
    TB
    Quote Originally Posted by vacuum3d
    Eric,
    thx,
    ernest
    I love this stuff...
    -DF
    KineticParadox ...a personal web space with my CBA Battery Testing and my LED Bin Coding Charts.
    Feb 2004
    Bay Area, CA
    Thanks DF. Gotta get me one of those.
    ernest
    Quote Originally Posted by TranquillityBase
    Thanks,
    TB
    Thanks a lot TB! That means a lot coming from you. I've felt that way about the tubes as well and agree on the parts. Chris does great work and I'll pass on the compliment.
    Here is a picture of a cree in a new canister on TnC Forums.
    I've added new parts to the TnC Online Store:
    18650 Tubes HA-Black
    18500 Tubes HA-Black
    AA Tubes HA-Black
    CR123 Tubes HA-Black
    18650 Tubes HA-Nat.
    18500 Tubes HA-Nat.
    AA Tubes HA-Nat.
    CR123 Tubes HA-Nat.
    Thanks for looking.
    Flashaholic* LED Zeppelin's Avatar
    Sep 2005
    Great Lakes
    Great new Eric, placed an order for the following:
    1 x TnC SF Natural HA recessed clicky tail cap $36.00
    1 x TnC SF Natural HA CR123 battery tube $33.00
    1 x TnC SF Natural HA power pack $30.50
    1 x TnC canister for mounting an LED and converter. $16.00
    Thanks, been waiting to build up the awesome 27 mm SF head into a complete light.
    Flashaholic SpeedPRO's Avatar
    Oct 2005
    SoCal
    Been waiting for this Eric,
    Just in time when you got the Black HA AA Tube to order and the 27mm Black HA head is gone, know when will you be getting more of it?
    -N O V E L-
    Feb 2004
    Bay Area, CA
    TnC SF Black HA recessed clicky tail cap $36
    TnC SF Black power pack to fit Aleph heads $31
    TnC SF Black HA 18650 battery tube $35
    TnC canister for mounting an LED and converter $16
    Email sent.
    thx,
    ernest
    Which one has a better color match, black or natural ?
    Flashaholic* jeffb's Avatar
    Dec 2004
    Indiana
    Natural and Black HA are both matched very well, as can be seen in pictures. TnC , Chris's products are always well anodized in my experience.
    Good Luck with your choice, I'm sure you will be very satisfied!
    jeffb
    Dec 2004
    Toronto, Canada
    bogus1,
    Did you get my PP and PM? Thanks!
    Hi Speedpro,
    We are making more black 27mm heads, but the platers' time frame is an unknown. It makes it impossible to predict exactly when I'll be restocking this part.
    Goldserve,
    I have your paypal from yesterday and expect to ship today.
    Thanks
    I'm sorry if my replies are late on this forum. Email notifications started to work again for a couple months for me and now just stopped.
    Feb 2004
    Herts, England
    Bogus1,
    do you have any pictures of whole HA Nat lights? to be specific a 27 head? The HA Black looks so cool, but I like the finish of the SFIII and hope I made the right choice!
    or jeffb do you have any more to show off
    thanks, Ian
