Results 1 to 17 of 17
Thread: Difference between Duracell ultra and Procell
    Sep 2006
    Central America
    Default Difference between Duracell ultra and Procell
    Curious if anyone knows for sure if there is any significant difference between these same manufacturer excellent cells ?
    Oct 2006
    Brooklyn, NYC
    Default Re: Difference between Duracell ultra and Procell
    Different packaging.
    Now plenticell, that you'd want to avoid.
    Is it like Energizer and Energizer Industrial?
    Same thing, different packaging?
    I have some Duracell Procell, haven't tried them yet. It seems Duracell cells for a slight margin over Energizer.
    Apr 2005
    Connecticut
    The experience I had with Duracell alkaline (not ultra) and Duracell Procell batteries is from my old job several years ago.
    We, my coworkers and I, were used to buying batteries as needed in a store and we bought coppertops. Well, there was an expense cutting initiative and we were required to order our batteries in bulk from WB Mason and the $$ amount we were then allowed for batteries did not allow for the regular coppertops. We bought Procells. We were used to having to replace the batteries once per month. With the Procells we found we would only get about 3+ weeks on a set of Procells. Basically, I would say they lasted about 80% as long as a regular coppertop.
    Brian
    Sep 2006
    Central America
    The procell 123A is actually more expensive everywhere than the Ultra. You would expect better performance.
    Apr 2006
    Chattanooga, TN
    When I took a tour of a semi local Duracell plant I found out that for each different brand/labeled battery they made, they used a different mixture.
    So all Duracell made batteries aren't equal.
    Could someone substantiate this?
    How about Duracell Procell vs. Energizer? Both AA?
    Interesting article here:
    http://groups.google.com/group/rec.p...91b32f2ae5d7b4
    I have read that the new Duracell Ultra AA alkaline batteries have a
    lower internal resistance then regular AA alkaline batteries. I would
    think this might make for better performance in digital cameras then
    the very subpar performance that normal alkalines give. Has anybody
    tried these out in digital cameras and if so what are the results?
    Silver Moderator
    SilverFox's Avatar
    Jan 2003
    Bellingham WA
    Hello Fenris,
    Very interesting...
    There has been a lot of speculation that Sanyo makes cells for a lot of other brands, and some of those "other" cells are less expensive than the Sanyo cells. I wonder if Sanyo does the same thing...?
    Tom
    Behind every Great man there's always a woman rolling her eyes...
    Most batteries don't die - they are tortured to near death, then murdered...
    Apr 2006
    Chattanooga, TN
    Quote Originally Posted by SilverFox
    Hello Fenris,
    Very interesting...
    Tom
    I wouldn't doubt it. All the discount stores and their brand "X" batteries have come to come from somewhere. Ya know?
    The thing with Duracell was that the slurry mixture for the different branded batteries were different. The Duracell labeled batteries are still superior to the other ones they make. They're not going to let brand "X" batteries out perform their own.
    Administratior
    Brock's Avatar
    Aug 2000
    Green Bay, WI USA
    My understanding is that pro-cells vs. regular Duracell’s are actually load tested before they are packaged where regular Duracell’s are not. We often go thought a couple 100 a week on big shows and we short test every one before they are put in to rotation. In about 10,000 cells I have tested I bet I have not found more then 5 that were low, not dead, but not in the range we wanted. When we use other cells I see a lot more low and dead cells, likely in the range of 1 in 100 bad ones.
    Whether this is worth it or not, I don't know, but if you have a mission critical situation and don't check all your cells before I would recommend them.
    Brock - Used to have some web sites
    Sep 2006
    Central America
    Thank you Brock. I just purchased a bunch of Duracell Ultras and Duracell Procells and the difference in price was $0.25 each. I have my own ZTS and test each cell before use in my M6. So this would make the extra money not worthwhile for me I guess as the formulation of both is the same correct ?
    BTW, I will be sending these cells, along with 6 other brands to Silverfox as soon as I get them for a shootout he will do at 2.5 amps draw.
    Oct 2006
    Brooklyn, NYC
    Ok I called Duracell and asked for someone who can answer a technical question and they transferred me over to one of their engineers.
    The procell and the regular alkalines are the same exact battery, made in the same plant, the only difference is the packaging (meaning it comes out of the same hole but goes down a different line in the plant for packaging).
    The differences in chemistry in the same alkaline battery are between their "ultra", M3, and whatever they have now that's one step above that. It's done so the batteries can have more current draw without suffering from as much voltage depression (making your digicam think the battery's dead even when its not).
    Also, between their manganese, zinc oxide, silver oxide, carbon, lithium, and nickel batteries, their chemistries would be different, obviously.
    Their #'s 2037913013.
    Apr 2005
    San Jose, CA
    The Procell products are a lower cost, lower capacity alkaline battery sold for industrial use applications. You can find the product data information from Duracell's site at http://www.duracell.com/procell/products/procell.asp
    Quote Originally Posted by LED61
    Sep 2006
    Central America
    I thank everyone who posted and my bad but I had to make reference as my interst lies solely for Lithium chemistry, so I'm still pretty much in the dark. I know we will all find out how good both are soon as Silverfox will do a shootout but if anyone knows differences in LITHIUM please post.
    Sep 2006
    Central America
    OK guys, its official. I called Duracell to the number SLVOID provided above (thanks slvoid) and spoke to an engineer. He confirmed the 123A´s Ultra and Procell is exactly the same cell, no difference whatsoever. He also mentioned that the battery is able to take 2.5 amps or even 5 amps pulses, but not extended runs, as this would trip the PTC circuit and shut the battery down. I mention this and asked this because many of our incandescent lights use 2.5 amps draw when used with the HOLA´s.
    Flashaholic* koala's Avatar
    Mar 2003
    Melbourne, Australia
    Very nice, the engineers know their stuff well...
    Arc4+ mods/repair. LED drop in for SF E-Series. Onion Rings for SF A2.
