Curious_character
- Joined
- Nov 10, 2006
- Messages
- 1,211
After looking at several "shootouts" among brands of CR-123A cells, I was a little surprised to find that the runtime of a Battery Station cell in my Fenix P1 was about 25% less than a Surefire cell. (Or, the Surefire cell ran about 33% longer than the Battery Station cell.) So I re-ran the test with two cells I received just a few days ago. Before I did, I checked the open-circuit voltage of both cells and their reported capacities with a ZTS tester. The flashlight was clamped in place and not moved during the entire test. The results were nearly identical to my original, more casual test.
Before the test, the Battery Station cell had an open circuit voltage of 3.27 volts, the Surefire 3.24. Both tested 100% on the ZTS tester.
Here are the results:
In dollars per minute, the Battery Station is cheaper considering what I paid for each. But for maximum run time, the Surefire is definitely better. I'd be careful about extrapolating this to other lights, and don't know how much batch to batch variation you'd see in the cells. I did get virtually identical results from two Battery Station cells from the same batch, and two Surefire cells from different batches.
This is my first time posting an image. Please let me know if I goofed it up.
c_c
c_c
