mtbkndad
- Joined
- Jan 1, 2005
- Messages
- 1,295
Here are the pics I took from the second shootout.
All XeRay shots in this shootout were done with the good DL50 Bulb.
Camera- Canon S2IS set to f3.5 and 6" auto white balance and ISO.
The area we are shooting has a very slight incline for approximately 100 yards. It is level for around 20 yards after that and then drops very gradually from there toward the tree.
Polarion P1
Helios
XeRay DL50 tight focus Reflector 1
XeRay DL50 tight focus Reflector 2
Now for some more direct comparisons.
Polarion P1
XeRay with Reflector 1 set to approximate P1 focus.
This is actually my favorite XeRay setting and wouldn't you know it, this reflector is not the one that comes with the light.
The P1 is a brighter in the fore ground in the photo and the XeRay is a brighter down field. When looking at these in person, it is really hard to tell a difference at this setting. However the cropped shots with their 6" exposure will show the down field difference.
Helios
XeRay with Reflector 2 set to approximate Helios focus
The Helios corona is still slightly wider. The XeRay lights brighter up close and to the sides at this setting. The Helios lights the tree and behind the tree better.
Once again, in person these are very close.
Now for the cropped shots.
The crops put the tree the lights are focused on to the left side, it is 146 yards away.
The rock above the tree is 312 yards away.
Watch the hill to the right of the rock and behind the tree as it gets brighter and dimmer.
The large tree to the right side of the photo is 132 yards away.
Watch how portions of this tree appear and disappear in the different photos
The vertical trunk in the background just right of center is 266 yards away.
Polarion P1
XeRay P1 focus
Once again, I really like how this configuration put light down field. While keeping a wide beam.
Too bad it is the old reflector 1.
XeRay Helios Focus
Helios
XeRay Reflector 1 tight focus.
XeRay Reflector 2 Tight focus.
My personal thoughts.
In terms of light output all three lights are quite comparable to me. The 40 watt Helios and XeRay with reflector 2 do seem to put out a little more light then the 35 watt P1 and the XeRay with reflector 1. The key term here is a "little" more light when looking at these in person. The difference in light output is by no means overwhelming. The different shapes of the coronas and distribution of light within the hotspots, coronas, and amount and brightness of spill make beam shots very imprecise for determining accurately the total relative light output of each of these lights or any lights for that matter.
I would like to measure light output in my light box some time. It is not an integrating sphere but would be a better way of measuring total light output then comparing beam shots.
The 35 watt and 40 watt Polarion products are simplly more efficient at getting more lumens out of the front of their lights with there perfect little reflectors. This is why they hold their own against the XeRay in terms of light output.
The XeRay has the advantage of being adjustable.
I do not think anybody should be too focused on the stated bulb lumens by either manufacturer. Bulb lumens and what comes out of the front of any light are often drastically different.
The lights are what they are and their output has been clearly demonstrated in multiple shootouts.
Here are a couple of pics of the lights in Mr Ted Bear's car.
One of the XeRays had a 50 watt ballast and one had a 75 watt ballast.
That way we were able to switch reflectors and the one bulb between the two lights with minimal trouble.
To me personally, the XeRays are rather large clunky boxy looking lights compared to the Polarion offerings. I also prefer a balance between flood and throw for most uses. That is why the focusability of the XeRay lights would be lost on a person like me. If you look at the Polarion P1 in the overhead photo you will also see the square ballast box on the bottom. While the P1 is significantly smaller then the XeRays, only the Helios is missing that rectangular ballast box. I have stated numerous times that my primary criteria for a high end HID search light is packability. I want a 35+ watt packable light and the Helios is the most packable 35+ watt HID light that I know of on the market right now.
Somebody emailed me a while back and asked me why I thought the XeRays are the best HID lights under $1,000. I replied that I never said that.
I would like to clarify once again I consider the XeRay the most versatile in terms of bulb and ballast options. My favorite bulbs in the XeRay were bulb's I believe Xevision does not even offer that Mr Ted Bear got for another shootout. They were 35 watt bulbs driven at 50 watts. One was a Japanese bulb and one was a Phillips bulb that was in a white box and that is all I know about it.
I personally think in terms of fit and finish and compactness and light output to size of the unit and other nice features they have, the Polarion offerings are the best lights available at anywhere near their price points. Of course they do not have adjustable beams, so if you do not like the beam patterns they offer you will need to look elsewhere.
When I borrowed BVH's Helios for the 3rd shootout it was a few days before he was able to pick it back up. I just loved taking people out on my long dark street and saying watch this. I would then turn the Helios on and light up the street perfectly evenly and bright 368 yards to the garage at the end of my block. Nobody said $1,595 is too much once I explained all of it's features and that was before I found out it is waterproof to 265 feet not 165 feet.
You really have to see, handle, and use a Polarion Helios to appreciate what a nice light it is and just how compact and packable it is in relation to the other lights in this test.
In summary all of these are nice lights with different features that create advantages and disadvantages that will determine which light is most suitable to you. All of these lights will illuminate people farther then you will clearly be able to identify (sex, height, weight, race, etc.)without binoculars.
Take Care,
mtbkndad :wave:
Polarion P1
Helios
Polarion P1
Helios
Polarion P1
XeRay P1 focus
XeRay Helios Focus
Helios
Take Care,
mtbkndad :wave:
