There is a quarter inch of space within the open end of the flashlight tube even without the spring-loaded contact pin on the top of the battery carrier being depressed (and, leaving out the truncated pyramidal spring, of course). However, the tail-cap screws
inside the tube with a full 1/4 " of threads.
There is a 1/8" recess in the tailcap. This space has a diameter of
11/16". Not a 1/4" recess, as you might expect, inorder to accomodate the lanyard device and leave the outside end of the tailcap recessed so that the lanyard nub doesn't protrude and you can set the flashlight up as a candlestick.
The tube, holding the battery carrier, has a diameter of
7/8".
Would the 18650 nest/fit into the small tailcap's space?
If you only partially screw in the tailcap you would get the needed 1/4" space in the tube.
oregon
