mrsinbad
Have any of you rolled your lasers on a table top while it is on just to see if it is centered in the module or holder? Just curious to see, as I was thinking it would be pretty cool to make my own bore sight for firearms.
I thought that's what you meant by "centered". In my limited experience with lasers, the beams are all a few degrees off axis from the body. The beam does start out centered in the body. Especially with green lasers (or most colors but red), the fact that there is a diode, two crystals, and a lens/IR filter makes it hard for the beam to be exactly parallel with the side of the body. As for the reds I have that are off, I'm not sure but maybe it's because they are so small.mrsinbad said:Thanks for the reply. If it's not centered, is it too much to expect it to be parallel the the side? Or is it really all screwed up.
