NewBie
*Retired*
Edison Edixeon EDEW-KLC8
Well, unfortunately, the slug is also anode, or positive, so it will need to be mounted with a method that isolates from the flashlight body just like the Seoul Semiconductor P4. Warning, both are backwards from the Luxeon III, if you do not isolate it, you very likely will blow up your LED, and possibly converter.
Both the Edison Edixeon and the Seoul P4 have the internal die height different than the Luxeon III, so you will need to shim it up and grind off a portion of the reflector (0.03" to 0.05"), or to grind the reflector, and set the reflector further back in the flashlight.
There are a number of further differences listed below.
Height is also short like the Seoul P4:
Luxeon III 5.86 mm (0.230708")
Seoul Semiconductor P4: 5.08 mm (0.1999994")
Edison Edixeon 5.1 mm (0.2007868")
Dome diameter:
Luxeon III 5.8 mm (0.2283458") (I measure 5.43mm)
Seoul Semiconductor P4: 5.6 mm (0.2204718")
Edison Edixeon 5.4 mm (0.2125978")
Dome height above body:
Luxeon III 2.9 mm to 3.39 mm (0.1141729" to 0.1334642")
Seoul Semiconductor P4: 2.7 mm (0.1062989")
Edison Edixeon 2.5 mm (0.0984249")
Slug standoff bottom diameter:
Luxeon III 5.25 mm (0.2283458") (I measure 5.43mm)
Seoul Semiconductor P4: 6.0 mm (0.1968498")
Edison Edixeon unknown
Slug standoff bottom height:
Luxeon III 0.25 mm (0.00984249") (I measure 5.43mm)
Seoul Semiconductor P4 unknown
Edison Edixeon 0.2mm (0.007873992")
Outside body flats (lead area):
Luxeon III 6 mm (0.2362198") (I measure 5.43mm)
Seoul Semiconductor P4 7.4 mm (0.2913377")
Edison Edixeon 7.2mm (0.2834637")
Datasheet typical lumens:
Luxeon III 65 lumens @ 700 mA & 25C internal die temp
Seoul Semiconductor P4 85 lumens @ 350 mA & 25C ambient
Edison Edixeon 85 lumens @ 350 mA & 25C internal die temp
Edison Edixeon 160 lumens @ 700 mA & 25C internal die temp
Note Edison Edixeon Warm White 70 lumens @ 350 mA 25C internal die temp
Forward Voltage:
Luxeon III 3.03V - 4.47V @ 700mA
Seoul Semiconductor P4 3.0 V - 3.8 V @ 350 mA
Edison Edixeon 2.8V - 3.7V @ 350 mA
Edison Edixeon 3.1V - 4.0V @ 700 mA
Thermal resistance from internal die to slug case:
Luxeon III 13 C/W
Seoul Semiconductor P4 6.9 C/W
Edison Edixeon 12 C/W
Maximum die temperature:
Luxeon III 135 C
Seoul Semiconductor P4 145 C
Edison Edixeon 150 C
Lens exterior:
Luxeon III hard
Seoul Semiconductor P4 soft silicone (gummy bear like Luxeon K4)
Edison Edixeon unknown at this time
Maximum Operating Temperature:
Luxeon III not specified
Seoul Semiconductor P4 -30 C to +85 C
Edison Edixeon -30 C to +110C
Color Rendering Index:
Luxeon III 70
Seoul P4 70
Edison Edixeon 74
Dome diameter:
Forward Voltage:
Luxeon III 13 C/W
Luxeon III 135 C
Lens exterior:
Luxeon III hard
Luxeon III 70
Seoul P4 70
Edison Edixeon 74
