Okay, well, I tested a second CREE, which is #2 on the overkill heatsink.
CREE #1 is already mounted on a 2" by 3" by 0.165" piece of copper sheetmetal only.
The device used for "brightness" testing was an Extech 407026 mounted to a white pail, such that the light from the LED would not have a direct path to the sensor. LED was inserted in a hole in the jug.
Meter here:
http://www.extech.com/instrument/pro...50/407026.html
Caveats:
-Like all light meters, it is not a spectroradiometer, and will have some error depending on the spectral output of the LED. Expect any errors due to spectral differences between LEDs to cast doubt on accuracy of measurements.
-CREE #2 was not mounted on the overkill heatsink, and it's thermal solution is different than the rest of the LEDs under measurement.
-CREE LEDs were both directly soldered to copper, NOT a MCPCB.
-The CREE LEDs were both from the "low output" P3 bin (73.9 - 80.6lm),
NOT the Q3 bin (93.9-100.4 lm) which would be in the Seoul P4 U bin range (91.0-118.5 lm).
-CREE #1's bin appears to be higher than what the vendor that supplied said it was. Possible mixup at the vendor.
For the testing to be fair, I'd need to obtain parts from the same lumen bins from Seoul and CREE. This comparision here is a bit biased, as I do not have any Q3 bins from CREE yet. Some folks have been running around saying the Seoul P4 is brighter than the CREE XR-E, which is dicey at best to say, since we are not comparing the same lumen bins. Of course a part from a higher lumen bin will be brighter!!! It may be that companies are paying premium for the top end CREE bins, like Surefire, and thus the lack of availability- *conjecture on my part*.
Anyhow, the new graphs:
The BIG version:
http://www.molalla.net/~leeper/sp4int3.png
