Seems like the hot setup for chargers is independent channels so that each battery can be treated and charged according to its own needs; plus if you have devices that use either 1 or 3 batteries (like so many LED flashlights these days) you need charging that isn't in pairs.
I'd also like to eliminate the "phantom load" that a wall transformer does causing it to waste electricity even when it is off (My Maha C204 draws about 1 watt and the C401 draws 2 watts). I see that the Sony BCG-34HE4 charger has independent channels and shuts off when done (meaning that it draws NO electricity).
http://www.amazon.com/dp/B0002IWC9C/?tag=cpf0b6-20
Are there any others like this?
One thing I've read about the Sony is that once it shuts off, it starts to drain the batteries a little if you leave them sitting there afterwards. Is this inevitable with such a design?
Thanks!
Thanks!
