why a backwards battery on a surefire 3DL?
benchmade_boy
not far enough away
ok guys heres the deal. i just got this surefire 3dl today and have been so mad cuz it wouldnt work i sat there for about 5ive hours scratching my head. so i finally gave up and called a good freind. we sat there and talked about how i got screwed over on a broken light and what if anything we could do to fix it.so finally he says" did you try and put the battery in backwards" i say" surefire has made hunderds of lights and none have taken a battery backwards" but i do it anyway and walla it works pure IR beam.
so my question, why did surefire make this battery backwards?
thanks!
Size15's
Kettering, England
Re: why a backwards surefire?
Actually, SureFire's Laser Modules require the batteries to be inserted "backwards".
My guess is that it's historic and to do with the electronics (or perhaps lack of?) requiring that correctly polarity is observed. I guess now-a-days it is possible to more easily allow electronics to deal with the polarity of the batteries.
benchmade_boy
not far enough away
yeah it is pretty old, copyright on the paper work says 1995. but you feel really stupid when you cant get a battery in right in a flashlight, then somone that know almost nothing about lights say try puting it in backwards, you fell really dumb:ohgeez:.
highorder
Michigan
I have read that the while the M1 has an output of 10mW, the 3DL has an output of around 35mW. is this correct?
benchmade_boy
not far enough away
i too have read that. so does that mean it will out throw the M1? or what will it do?
BTW i just read the instructions again and it says to place the + terminal forward not backwards and in the picture it shows it facing forwards not backwards.
Size15's
Kettering, England
I don't know. I suggest you call SureFire tech support and ask.
IsaacHayes
Missouri
A lot of "warm" leds have the postive connected to their heatsink slug. Such as red, red-orange, and amber luxeons. Infrared is also like this led chemistry and so that may be the reason.
Also, my red laser pointer requires the batteries to go in "backwards"
benchmade_boy
not far enough away
so my good friend (the one that told me to put the batt in backwards) called surefire and the rep said that there was no differnce in the 3dl and the m1 just cosmeticly. do are they blowing smoke up our butts or not? i mean mine say 35mw and the M1 is rated at 10mw so there has to be a differnce. i guess i will find out when we compare the two.
Size15's
Kettering, England
I didn't think there was any difference between the insides of the M1 and it's predecessor, the 3DL.
I don't know of any online comparison of the two.
Al
InfidelCastro
Banned
USA
I saw when you got that on B/S/T. That was a nice grab, I was a few minutes too late!!!
