heliyardsale
- Joined
- Dec 6, 2006
- Messages
- 168
How long should it take to refresh 4 Energizer 2500 Mah batteries? I set the discharge rate for 350 Mah. It's been going for 24 hours is this too long?
Heli
Heli
macdude22 said:Several days at worst, couple days at best. Refresh will charge at 700 mah and discharge at 350 mah with your settings and keep running cycles until it doesn't detect a change in capacity. At best you will have to run through two cycles likely more. By my terrible not precise calculations it will take 12-13 hours to do one cycle at those settings.
heliyardsale said:Thanks for the heads up. How do I tell if its discharging or in the charge portion of the cycle?
coppertrail said:The LCD display should show "Discharge" for each respective cell when it's discharging.
