PEAK
Results 1 to 9 of 9
Thread: HELP USB SPEAKER PROBLEM.
    Flashaholic* TinderBox (UK)'s Avatar
    Jan 2006
    south shields, england, united kingdom
    Help HELP USB SPEAKER PROBLEM.
    I just bought some usb speakers yesterday, my problem is they make an popping, crackling sound.
    I found that they only do this when my cpu usage is very low, 0-5%.
    they way i found this out is when playing music in windows media play 11, if i have the visualization running, you know the dancing graphics - the sound is perfect.
    but if i minimize the player or stop the visualization the popping noise returns.
    I have tried re-installing the usb driver, and the chipset driver - no good.
    can anybody help this is doing my head in.
    edit : this also happens in nero player and powerdvd, i downgrade to WMP 9, no good.
    thanks.
    John.
    Intellicharge i4 - LaCrosse BC-900 - MaHa C9000 - Charge Manager 2010 - Vanson Speedy Box - Accumanger 20 -Thunder AC6
    Solar - GoalZero Nomad 7 + Guide10 - Powerfilm USB+AA Solar Charger
    Flashaholic* gregw's Avatar
    Jun 2004
    Hong Kong
    Default Re: HELP USB SPEAKER PROBLEM.
    Found a patch at Microsoft that specifically addresses popping in USB speakers here. Hope this helps.
    Jan 2006
    Hi gregw
    I found the patch the other day i can`t install it, I already have XP Home SP2, so i think i already have the patch.
    I have already tried upgrading the usb driver and installed somthing called a filter patch.
    but the sound is still the same.
    can anybody explain to me why the sound is perfect with high cpu usage, and it pop`s and click with low cpu usage.
    thanks fore the help
    John.
    Flashaholic* Arkayne's Avatar
    Nov 2005
    San Diego, CA
    I've had simliar problems with usb headphones. The fix was to use a USB hub with its own separate power supply. I remember reading that the motherboards built-in usb power supply was "dirty" so you get pops and crackles. It's like having a bad ground in a car audio setup where you would hear the alternator whine and even the turn signal relay through the speakers.
    Jan 2006
    Hi Arkayne.
    I have tried an USB 2.0 hub with an external power supply, no difference.
    I think it`s some type of compatability issue with my usb 1.1 ports, the driver is windows standard "USB AUDIO DRIVER" dated 2001, but i have searched for updates without success.
    keep the suggestions comming
    thanks
    John.
    Nov 2005
    San Diego, CA
    Hmmm, I'd stray away from the built-in usb hardware and give a newer usb pci card a shot. They can be had for $5 - $10.
    Jun 2003
    SF Bay Area
    I don't think that this is your problem, but it did fix my issues with on Window's XP Home writing (proprietary) memory cards for my GPS. The problem was that the power management feature of USB (at least on a laptop computer) would cause the writes to fail over the ten-twenty minutes it would take to compile and save the data...
    First, I turned off power management features (right click desktop, Properties, Screen Saver, Power, turn off any power management--I only needed to this for "wall powered" mode. I left the battery operation settings alone since I was doing this with AC power available).
    Next, click on Settings, Control Panel, System, Hardware, Devices, Universal "+" Serial Bus Controllers, Right Click each of the sub devices (probably only the ones with "root hub" in their descriptions, click on Power Management, and un-check the box where it says "allow computer computer to turn off this device to save power". On my system, there are three "root hubs" that I need to un-check this box for.
    I don't think it will fix your problem--but it is worth a try.
    -Bill
    Flashaholic Raybo's Avatar
    Apr 2004
    Illinois
    TB,
    Give this a try, open up your (Windows) volume control and crank your speakers with no media playing so you can hear the backround pops. Try "ticking" some of the mute boxes, if the poping stops than try some music to hear how it sounds (if it plays at all).
    Ray
    Jan 2006
    Hi. BB
    I tried what yo said, but it was to no good.
    I might try upgrading the graphics software.
    keep the suggestions coming.
    Thanks.
