LEDcandle
I've got a plastic light formerly hosting a direct driven TY0K, which ran nicely at about 400 ma (li-on DD) and heat was manageable.
I swapped it out with a Cree XR-E (heard the Vf of these are around 3.4v at 500ma) and now it is driving at 800ma or so. Very nice and bright, but too hot for a plastic housing. Heatsoaks in minutes.
Everything is pretty much fixed in, so I can't install a converter now. The only thing I can think of is to add a resistor somewhere, and I plan to add one to the tailcap spring.
Original, current will flow through the spring along its coils. I know some people add solderwicker or wires from the top of the spring to the bottom to REDUCE resistance by providing more flow.
Now I want to do the reverse; can I add a resistor connecting from the top of the spring to the bottom? Will this add any significant resistance or will the current bypass the resistored path and still go on its merry way originally?
For e.g. __(10ohm)___
(-)-----|___________|----(+)
Will the above provide any resistance? Or will the current bypass the resistor and still continue to flow thru the open path?
