e=mc²
Terrible.
<font size="2" face="Verdana, Arial">That would take too long. A shuttle doesn't carry unlimited consumables. Even if you had enough air, food and water the APUs would need fuel to continue making electricity.Originally posted by Ted the Led:
would sending up a second vehicle to make repairs have been out of the question?
<font size="2" face="Verdana, Arial">They are incredibly poor conductors of heat. You can in fact touch them that quickly: they're still very hot (glowing) just under the surface but that heat can't transfer through the tile easily to your fingers.Originally posted by CiTY:
The ceramic tile they use are very custom. I hear you can almost touch them a few seconds after taking them out of a kiln.
<font size="2" face="Verdana, Arial">There will be political reasons not to waffle this time. Congress will not be happy buying launches from the Russians. Moreover the Chinese will do a manned launch later this year and the US will not want to be left out.I guess the shuttle program will be grounded for a while.
<font size="2" face="Verdana, Arial">Apparently the tile repair kit hasn't flown since STS-2?Originally posted by James S:
They can replace tiles in orbit, that was one of the things they worked very hard on during the initial design of the thing.
But just loosing one, or even several tiles is not enough to cause the skin to fail. The shuttle routinely looses a tile or 2 and there are a few very vital places where loosing one is bad generally it's not that big a problem.
<font size="2" face="Verdana, Arial">OK, time for corrections:Originally posted by James Van Artsdalen:
I don't think you can refuel the APUs in orbit so even if the tiles are repaired the craft would be dead and can't be recovered.
The airlock is heavy and I think it is sometimes removed if it can't of any use in the mission and the weight is needed for payload.
Going to the space station isn't an option. Its orbit is very highly inclined (due to the location of the Russian launch facilities) and expensive in fuel. Also, the station's systems can't accommodate so many people – as many as possible (3-4?) would have to leave immediately on the emergency return rocket (a Russian capsule always present) and there might still be too many left. Cooling would be my first concern: people generate a lot of heat and cooling is a big problem in space.
Lastly notice there isn't a toolbox "Tile repairs: Space Shuttle". Each tile is different with a custom shape and thickness. The adhesive probably wouldn't dry properly in a vacuum. It might not be possible to do the repair in zero-G with nothing to push against
<font size="2" face="Verdana, Arial">There were a lot of problems that had to be solved on Apollo 13, many of which weren't a matter of a Smart Guy saying Eureka!Originally posted by Ted the Led:
..do you think this forum could have come up with the solutions that saved the Apollo 13 ? Or would that have been "impossible" -- ? ...
