Sold:
Mag625R (4400 lumens) w/ 2 sets of cells.
This light is a Mag625R similar to AWRs Mag625R except longer. It's built in a 6D Mag body with a 1D extension to hold 11 4Ah 1/2D NiMH cells. The custom Hotdriver is set to 12.7 volts. I placed aluminum foil between the insulation and the inner surface of the Mag body to reflect IR back inside the body instead of being absorbed by the aluminum tube. The foil and refractory insulation are absolutely necessary to allow more than 5 minutes of run time. At 8 minutes the head becomes uncomfortable to hold. There are no marks on this light. It is flawless.
Included components:
6D Mag Black
1D extension
2 x Osram 64625 Bi-pin bulbs
Camless MOP reflector
Boro-float lens
AWRs Hotdriver (Special for Mag625R)
KIU ceramic socket
Ceramic refractory insulation
Tail spring fix
11 x 1/2D 4000mAh NiMH batteries
Another 11 1/2D Cells
PVC charging tube (I'll put banana plugs or Tamaya connector per buyers choice)
Shipping will be via DHL ground. I'll cap this at $20 any where in CONUS. Was originally capped at $15 but the weight of the additional cells will raise shipping costs.
Beam shot comparison with a Mag138. The Mag625R is on the left.
The first
gets it.
