Hello BBL,
Li-Ion chargers are supposed to shut off at the end of the charge. It appears that these chargers continue to trickle charge after the green light comes on.
Trickle charging after the full charge is not healthy for Li-Ion cells.
4.200 volts was chosen as a full charge in an effort to balance capacity and cycle life. When you charge to 4.200 volts you can expect 300 - 500 cycles from your cells.
If you charge above 4.4 volts, you are very close to the voltage that triggers rapid venting with flame.
If you charge to 4.3 volts, you will get roughly 18% increased capacity, but your cycle life drops down to roughly 10 - 20 cycles, or less. I don't think this is a worthwhile trade off.
Continuing to trickle charge at the end of a charge cycle, and charging to a higher voltage bring you closer to a rapid venting with flame incident. I prefer to use a charger with a "proper" charging algorithm. It may initially cost more, but my cells will last longer and in the end, it may actually save me some money. On top of this are the safety issues.
Tom
