AndrewL
- Joined
- Dec 8, 2004
- Messages
- 105
I bought a fancy charger to use with my bike lights and anything else I get that needs charging.
The charger can be seen here
http://www.alshobbies.com/shop/lookupstock.php?pc=6209&Desc=
I've modified a PC power supply to provide me with a 12v (or there abouts) power source for the charger (using a spare 6v MR16 to put a load on the 5v wire to get 12v from teh 12v rather then 10v)
I put 4mm plugs on the battery pack so can plug it directly into the charger. I just don't know if I'm meant to put the positive to negitive or vise versa.
Also my power pack is built from 24AA cells (better power cells claiming 2700mah) set up to give 14.4 nominal volts in two banks of 12. Should I charge each set of 12 cells on their own or leave all 24 wired up? I've heard it's bad to charge Nimh cells in parrallel.
