Gordov2
I'm seriously thinking of ordering the new Surefire L5. However, I would definitely like more than 120 lumens. Is this possible? If so, what is the best way to accomplish this?
Thanks!!
Thanks!!
I have six different lights which have either a Cree or SSC LED which all measure between 105 and 120 lumens in a Quickbeam light box, five minutes after turn-on. I have only one, a direct drive light running a SSC LED from an RCR123 battery, which is over 120 lumens -- it measures about 140. I haven't measured the current, but I'm certain it's overdriving the LED. My conclusion is that about 120 lumens is about all you'll get from a single Cree or SSC LED if you keep the current within the 1 amp spec, and have normal reflector and lens losses. You'd have to overdrive it quite badly to push the lumen output up by 20%, which is just barely enough to notice, if you can detect the difference at all. You'd also take quite a hit in run time for that very modest increase.Gordov2 said:I'm seriously thinking of ordering the new Surefire L5. However, I would definitely like more than 120 lumens. Is this possible? If so, what is the best way to accomplish this?
SureFire garantees a minimum of true 120 lumens for the new L5. We're most likely find out that these new lights will produce more than that in real life-- as usual with any SureFire product. The old L5 is rated at 100 lumens, but a lot of people have measured an actual output of around 120-130 lumens.Gordov2 said:Well, I am going to be ordering the new L5 and want to be able to increase lumens to over 120. Also want good runtime. Is there anything out there that can accomplish this?
