Re: DX: L1P type with Seoul !!
LEDninja said:
Unfortunately the 1500/2700 ratio can NOT be used to calculate the Lumens of the other light as it ignores the difference in the amount of light in the spill.
I may have accepted what you say, in part, apart from the fact the figure you should be quoting is 3,700, not 2,700 !! (Twice !)
Approx 65 lumens min is not arrived at by calculation, but by empirical means.
This may of course be higher when production model received.
You quote Kyle's reply ( to my question !!), and I am of the opinion that the 65 lumens mentioned for the cheaper 1.25w light may be a bit optimistic, when you bear in mind 3w is quoted around 140 lumens, when the P1D-CE is only quoted as 135 lumens, and the L1D-CE at 90 max.
You omitted the bit about the higher output WF501B Cree, which I also possess, with a quoted 3,600 lux etc...
(Maybe expect around 85 lumens, as per WF501B Cree)
Enough of this, the thread is to announce the arrival of the 1AA SSC P4 torch, that is all.
