Barbarin
Why do tailcaps get too hard under pressure? Is there anything we could to to avoid it?
Most of the people here won't dive with their lights. but pressure can be inside or outside the light. You can find that an overdischarge, or a failed battery have generated too much pressure inside the tube of the light, and it is very difficult to open it. The solution proposed here does work pretty well, but...
IMPORTANT!!!: If you ever need to open a flashlight that probably has pressure build up inside the battery tube don't forget to take as much precautions as possible. No flammes nearby (most of the times gas is hidrogen), clear all the way of the tailcap because it could be "shot" or projected with liquids, batteries...to anything or anybody, use protection gloves, safety googles. A safe environment.
Here is a drawing we made time ago. (it is in spanish, but translated)
Presión: Pressure.
Grasa: Grease.
Superficie de contacto: Contact/Friction surface.
Antigripaje: Antiseize
This is the way things happen. Pressure forces a movement that makes surfaces of the thread area to increase friction, as all the grease or oil is moved away (Red lines show the maximum friction area). When we are using an antiseize grease the micro balls of graphite or MoS2 are not moved away because they are solid, and they act as bearings, not allowing surfaces of the thread to get in contact.
So simply use your graphite pencil and your regular oil or silicone grease, and things will get easier.
Regards,
Javier López
BTW: I was not sure about what was the correct sub-forum to post this, but as this is an issue related to safety and flashlights I thought the general flashlight was the best one.
Presión: Pressure.
Grasa: Grease.
Regards,
Javier López
