sflate,
New Breakthrough from Sanyo - SUPERLATTICE ALLOY TECHNOLOGY
Advanced NiMH Technology - Holds a charge longer, with slower self discharge than other NiMH Rechargeable Batteries Made in Japan.
Does anyone have any experience with these? Is the 'slower self discharge' anywhere near that of the Hybrids or Eneloops? If not, are they significantly better than the typical NiMH?
Of all the batteries that I or any of my research team members have used, the Sanyo 2700 mAh NiMH AA & Titanium 2700 mAh NiMH AA's are hands down the very best batteries we have ever used, hands down! We use Prinection Tec Apex Headlamps and we get about 4 hours (Most of the time over 4 hours) of runtime on the high 3 watt setting, about 30 minutes better then any other battery we have ever used. As far as capacity goes, I'm 100% sure you can not buy a better NiMH battery. They are truly amazing!
As far as the "slower self discharge," Silver Fox or someone else with the proper tools could better answer that question. I do know that they won't match the Eneloops batteries as far as "slow self-discharge" goes, but the Eneloops don't come close to matching the Sanyo 2700 or Titanium 2700 NiMH batteries capacity for much longer runtime in headlamps or flashlights and you'll get many more pictures with you digital camera. I can tell you that the Sanyo or Titanium 2700 batteries will hold a good charge for weeks. I have a set of Titanium 2700 batteries that I charged over 7 weeks ago, and after two weeks the test at 80% on my ZTS MBT-1 Battery Tester, and it was 7 weeks to the day two days ago (this Thursday) that I charged them and they still test at 80%! I haven't seen how well the Sanyo 2700's hold their charge, but I know they will be just as good, if not better, then the Tatanium batteries.
I would say that the Eneloops would be better is you use them in a device that you seldom uses, and it goes 3,6 or 8 months between uses. But if you use the device often, or within a few weeks, or if capacity is more important, the Sanyo 2700 NiMH Batteries are un-surpassed in performance.
I hope this helps you out. Best of luck with your pick.
