liveforphysics
- Joined
- Dec 4, 2006
- Messages
- 343
Ok guys, I've been having everybody tell me that TO220 case LM317's can't fit into a 1AA flashlight body, and yadda yadda. So I decided to take it all apart again to snap some pics in efforts to hopefully conclude the stream of emails and things.
This is a photo "how to" guide.
This circut enables the violet diode to actually get the power it needs, unlike all the 5 and 5.1v stuff that barely or doesn't meet threshold current.
The SMT cap is 1mfd, and its its filtering the output to the diode. The resistor is 100ohms, and it's also in parallel to serve as a minimum load on the LM 317 to set voltage to a safe point before adding the LD.
The tab on the TO220 case LM317 has been snipped off an filed a bit on the corners. The pot was a large one, but it also happens to be a very accurate and smooth pot for making tiny adjustments, and it all fit, so I used it rather than a smaller unit. It was originally going to just be to dial in the circut before replaceing with a smaller pot or a fixed SMT resistor combo, but since it all fit, this lets me retain smooth adjustablility.
Ok, here come the pics.
