I have a older MM Q3L dated 2002 in my MM that has started to flicker on and off and to drop down in light output to just a dim spot. After twisting off, the output will return as normal but do the same thing after another few minutes. Everything has been checked. Cleaned threads, contacts, removed any possible corrosion on module surface, new batteries (several sets), exchanged MM tubes, etc. all to no avail. Only possible scenerio left is that the module has started to give up the ghost. I've also started to have thoughts about finally getting a newer U-bin drop-in. Any thoughts or suggestions?
