Hi,
I'm having trouble in designing a power supply to drive a 2W laser diode. Particularly in making the adjustable current limiter part. At the moment I'm using a huge resistor in series with the diode and it's not very versatile at all. Can anyone suggest an adjustable current limiter circuit by any chance? I've been trying to build one based on LM317 / 350 / 338 linear regulator but no success so far. For your information, I would need to feed around 2.5A at 2.2V to the diode. Any help will be much appreciated.
PS: Any of you guys have experience in building a DPSS laser unit based on c-mount as the pump diode? What do you guys use as the power supply? Care to share?
Thanks in advance.
Thanks in advance.
